kiltedcelt
So, I'm going to come right out and say first of all, that I'm completely happy riding my e-bike at around 18-20mph most of the time. It's kinda fun once in a while when I can get it to go above 22 or 23 mph. It's gone as fast as I think 27 or 28 once or twice. However, if I was hard pressed I'd have to say that I think I could live with 20 mph as an upper limit. All of this started when I investigated insurance for my bike. I've taken to riding my e-bike as my sole commuter, and I'm concerned about issues like the entire bike, or maybe just the battery being stolen. I was looking into insurance coverage for these reasons when I found out on the bike-specific policies like from Velosurance, that you're limited to the federal regulation that says the motor must not exceed 750w and top speed must not exceed 20mph. Of course we've all been there with the flawed logic that you can insure a regular bicycle through one of these companies with no issues, even though you can ride that regular bicycle (if you're a fit rider), to top speeds well above 20mph! So, we're not going to change federal regulations - we'll just have to live with that.
I never intend to leave this bike locked somewhere unattended for any length of time but as it is intended to be a car replacement (I *am* entirely car-free), there might be occasions where I might need to leave it locked to a bike rack for a few hours, say taking a trip to the museum, or perhaps visiting a friend and needing to lock it to a rack, etc. When possible I'd lock the bike with two U-locks - one through the front hub motor/frame, and the other through frame to bike rack, capturing rear wheel (which has Alfine 8 hub), if at all possible. The battery is currently a 36v dolphin case that locks to it's cradle, but I have an upgraded 28.3Ah 50.2v triangle pack that I'm going to switch over to using as soon as I can build a hard case for it. The triangle pack I intend to install in a case built into the main triangle with aluminum sides with the one side access panel having two keyed-alike cam locks to hold the access door closed. The sides of the case will be held on with pin-in Torx screws to prevent further tampering. Of course, if anyone really wants to steal it, they'll figure out a way to get the whole bike or just the battery if they really are determined.
So, I figured as a last line of defense against the fairly serious amount of money (based on *my* budget), that I've put into this bike I'd look at insurance options. I have a renter's policy but it's not going to give the coverage I want. While it *might* cover my regular bike, it probably *won't* cover my e-bike. Only problem, is currently the bike with it's 25amp controller and 36v battery means the motor is effectively 900w, and I have used those 900 watts on occasion to try to maintain a speed of 16-18mph when I was battling major headwinds going to work, and that was *with* pedaling pretty furiously as well! I'm going to guess right off that if I play with the settings in my Cycle Analyst, I can easily limit my max wattage to 750w, but is that going to mean I can no longer achieve 18-20 mph? With the new battery installed we're actually talking about 1255w possible coming from the motor! I'm not even sure I *want* that kind of power coming out of a front geared hub motor to begin with. This is a seriously torquey 16T Mac motor, and it is installed in a cro-moly steel fork with a Grin Tech torque arm on each side. Still, I'd thought about dialing back max output some anyway.
When I had a car, I never worried about someone stealing my crappy Subaru or Volvo wagon, but I know that my nice e-bike could potentially be a very attractive target for theft. So, that's my dilemma. Do I just do my best to make my battery as theft-proof as possible and lock the hell outta my bike when I have leave it somewhere for any length of time, and just hope for the best? That seems like the only way to maintain some sort of decent performance level in terms of motor output and what I expect, and have become used to in terms of how this bike behaves. The alternative is to de-tune it which I suspect is going to turn it into a real dog in terms of performance. Mind you, it's a Yuba Mundo and as it's outfitted right now with the 36v battery it weighs 82 lbs! With the 50v battery it's probably going to end up weighing more like 86 lbs! All that weight I suspect kinda means I *need* more "oomph" in the motor department in order to get the thing to go up to 20mph. With that being said though, when I'm riding at the 50% motor power PAS setting I currently have as my lowest setting, it only uses about 250w of power from the motor and can usually maintain about 18-20mph just fine. I'm just wondering if this is really going to suck if I de-tune the bike. Seems like de-tuning is the only way to be assured of being able to get insurance coverage.
Of course I could also be just incredibly paranoid about theft. After all, another Yuba owner traveled all around the perimeter of the U.S. on his electrified bike and often left it locked up outside of a Wal-Mart overnight to recharge while he was off stealth camping in the woods nearby. Maybe I'm just being a worry-wart...
