OK, if the wiring was previously tested on that controller, it shouldn't change.
If your batteries are good, they should be able to supply 100A for a short burst no problem. But they might not be good.
So the test is to measure the battery voltage while you try to get it going on the ground and see what happens. If the voltage drops below a certain point (which should be listed on the controller label), it cuts power to the motor. This might happen pretty fast, so apply throttle slowly.
Ive been at work the past few days but today I wanted to give an update on this project. First of all, the cart runs very well.
I was able to ride on it with my son. Combined we weigh roughly around 250-280 pounds. So the motor is definitely strong enough for this cart. The frame (which came with the chain) was very used and old. When I assembled the chain and sprocket with the motor, the chain was very tight. After messing with the cart and taking it on test runs for about a week, the chain seemed to have loosened up a bit and now there is some slack. This makes me think that perhaps the motor would not turn at first because the chain may have been too tight. I dont know for sure.
I also used a multimeter to check the voltage of the batteries. Output was right around 50 volts. I checked the voltage coming off the batteries with the back wheels of the cart off the ground and the motor spinning at full speed still had around 50 volts output from the batteries. I was attempting to check the voltage with the wheels on the ground (this is where the cart would usually get stuck and the motor wouldnt turn) but whenever I would step on the acceleration pedal, the cart would start moving. After a few attempted I just sat in the cart and tried to drive, and sure enough it ran just fine.
Some other things to point out: Today when the cart started running, I had all wires from the batteries tightened. Initially when it wasnt working, the battery cables were only hand-tightened. There was connection but the nuts/bolts were not fully tightened. Maybe this is why the motor had trouble turning. I did not check with the multimeter before when the wires were loose, so I dont know how many volts the batteries were actually putting out to the motor.
Another thing that I did not mention in my initial post that I think is important. When the cart was not running, the motor would not turn but it would make a continuous noise as if it were trying to turn but was stuck. I dont know if this is because mechanically it was not strong enough to turn the axle (perhaps because the chain was too tight) or because electrically the motor wasn't getting enough volts (since before the connections were not fully tightened).
Unfortunately I cannot determine exactly what the issue was with the cart. Maybe the old chain was too tight and now that its loosened a bit, the motor can turn easier. Or maybe the wires from the batteries just werent getting a good connection and the motor wasnt getting the full 48 volts. Either way, the cart runs great and it can carry a lot of weight. Very fun. Maybe someday I can upgrade to a more efficient battery. Pretty good for a first project I think.
I was not able to check the voltage output of the batteries while I was riding it but I'll see if I can do that later on
