Thud said:is your front brake on the left.
On motorcycles the front(most important one if your serious about technical riding) is on the right along with the throttle.
Look at any photo in an off road magazine of a rider exploding out of a berm & you will notice he has at least one finger still resting on the front brake lever. A twist grip will allow you to do that most efficiently. Top pros train to hold on with the thumb, ring & little finger. the index & middle finger are for extrainious controls.
& yes....often brakes & throttle are used simultaneously in the most technical riding scenarios.
For me its a twist every time.
Interesting, it does seem dirt bike riders do cover the brakes and use the throttle. Although some say that doing this does compromise the control.
You see a thumb throttle gives you precise throttle control and also precise braking control at the same time, and also allows you to even lift up hard on the handlebars to lift the bike while still having precise braking and throttle control.
I will have to determine if the twist throttle still allows the same degree of control when covering the brakes. Like if you didn't cover your brakes with the twist throttle, would it give you better throttle control? If you say yes, then the thumb throttle is better because it doesn't matter if you cover your brakes.
I find it really surprising that dirtbike riders can do this, and also give full throttle while covering the brakes. On my scooter if I go full throttle really quick I can not keep my finger on the brakes, but this could be just the setup.
