Isolated or non isolated DC DC converter
Cuprani
Can anyone please explain why I need an isolated DC DC converter?
I've had a non isolated 72V-12V DC DC converter on my old ebike setup (20S Li-ion with Leili 5000 watt squarewave controller) and it worked perfectly. (not the controller, but the dc dc converter).
I'm currently building a new setup with a 72V 20S li-ion battery and a Kelly 7230S sinewave foc controller.
I recently discovered my old DC DC controller has died and I need a new one for my setup.
I know the basics of electronics but that's about it. I know an isolated DC DC converter has got it's own ground wire. Using the same ground for both the Engine/Battery and 12V system could give ground loops?
How could this ground loops interfere with the engine management? How will this affect my ride?
Short: Do I really need an isolated converter?
The non isolated are a lot cheaper and better available in waterproof and smaller housing.
You probably don't. As long as you follow good grounding practices and understand your ground return paths you are probably fine.
I know isolated is needed with multiple units, when outputs get connected in series to boost voltage, or at mid-point taps, say 2x 36V converters (or PSUs) to charge a 72V bank without having to break/reassemble the two halves.
