electric_nz
- Joined
- Jan 7, 2019
- Messages
- 311
These are amazing! Such neat and tidy work too. Love the old school prelude
jonescg said:I used aluminium and had them nickel plated using an electrolytic process. Not cheap, but it appeared to work. It leaves a dull grey metallic look, and if you put it under a microscope it probably looks like a stack of spheres. In any case, the layer of nickel meant there was enough resistance to generate heat during spot-welding to take a 0.07 mm nickel tab.
[youtube]jumFyhtjylM[/youtube]
Multiply that about 10,000 times...
[youtube]N6nKPmhSE5g[/youtube]
In the end, the poor spotwelder had done so much work those long electrodes were worn down to a nub, my hands were sore and burned, but I made 4 complete double-sided modules.
The next step was to coat the welded faces with a thermally conductive epoxy resin and glue a sheet of G10FR4 to it on either side.
End result - a pretty much sealed, waterproof, rigid, robust battery module. The BMS wiring went to a pair of ZEVA BMS modules as 12s units plus four thermistors per module.
jonescg said:Hi Art,
I used a filled resin from a firm in China. Its a two part mix with a thermal conductivity of around 1.4 W/mK which is typical for these non-conducting resins. I'll look it up.
Edit: The thermally conductive epoxy resin is from a company called U-sheen www.sheenthermal.com And it's product ID is epoxy S8960.
Very nice battery building,Stuart Jameson asked me to build a special battery for a unique project - salt lake racer at Lake Gardiner.
One problem with these LiPo cell packs, is that you don't know the exact dimensions of the battery until its built. The cell supplier might assure me they are 7.8 mm thick, but they are more like 8.0 mm thick, and after stacking 40 of them together you have an enclosure which is a wee bit too small...
He specifically asked me not to glue the cells in place as he wanted the option of taking them apart. I advised against it, but the idea was it would so a handful of runs on the salt and then not get used for ages, so it was worth the risk.
There are some research papers I've linked elsewhere on this forum which go into how much compression these cells need, and it's a bit of a challenge to get right. If you used a compression arrangement with limited give, as the cells expand with age the pressure on them increases. Ideally the pressure applied would be constant throughout its whole life, so there needs to be some kind of polymer between the faces of the pouch cells to accommodate the changing pressures. I think Poron was one such material which doesn't collapse over time. The downside is the bulk it adds to the pack assembly, and weight.Very nice battery building,
i am building a 24 s 1p lipo kokam cells 67ah would like to know how you figure out the compression needed, I want to build like you, with polycarbonate,
do you fold the side and bottom seam flat against pouch ?
How do you manage the difference between aluminum and copper?
Thanks
Thanks very much for that, You do nice workThere are some research papers I've linked elsewhere on this forum which go into how much compression these cells need, and it's a bit of a challenge to get right. If you used a compression arrangement with limited give, as the cells expand with age the pressure on them increases. Ideally the pressure applied would be constant throughout its whole life, so there needs to be some kind of polymer between the faces of the pouch cells to accommodate the changing pressures. I think Poron was one such material which doesn't collapse over time. The downside is the bulk it adds to the pack assembly, and weight.
I've moved to cylindrical cells full time now, and wouldn't recommend pouch cells for anything other than high performance applications like racing vehicles.
As for the seams around the edges of the cells, my pouches all had a flat base, so standing them upright was no big deal. But I do know that the Kokams have a seam all the way around. I think from memory they use a plastic gauge separator which fits around the outline of the cell, allowing it to be clamped into place without deforming the edges.
As for aluminium and copper - the two don't play nice, so you need to have a conductive grease like Aluminox (Vaseline and zinc powder) between both clamped surfaces. They cannot be welded or soldered (unless it's nickel plated aluminium) so screws are pretty much the only way.
Hope that helps!
Chris
Haha, yes, I've been known to do things barehanded before and remarkably never had the ring short stuff.Still reading... could you do something on safety? This is a real education, I'm an open source evangelist and even from that angle this is exceptional documentation. In some of those pics you're handling packs in bare hands with rings, seriously well engineered packs and you still have all your fingers, what's the important stuff?
You can see I used expandable foam on the new 12 kWh race bike battery. Not much I might add - just enough to secure the balance wires. But you can get low density potting compounds that aid waterproofing and vibration protection without massively increasing mass. They are generally good at keeping the cells warm when they get hot, since it's effectively an insulating blanket.Thanks! That gives me some confidence there. Another reason for PC over alu for me is cost; I expect that waterjet + brake bending + tig would run me over 250 eur for the box, while the PC i can cut myself and the total cost will be like 1/10th. For durability, I should've clarified it will be an enduro bike, so dropping on stuff as well as being splashed with water is totally expected and i have to plan for that.
Potting the battery sounds tempting; what do you think about expandable foam (like the one used for building insulation)? Cheap, durable, much more lightweight than any resin. Might compress a bit over time, though.
