jonescg's NEW electric racebike BUILD thread!
It's funny - I was asked to leave metalwork in school because I was just so bad at it. I wasn't much good with electronics or drawing... or anything really. So I became a chemist, then a plant scientist. But with a bit of maturity and some space, I learned a few things and bought a few tools (roughly 13 years ago) and have just kept on trying stuff.
Glad everyone here can learn from it too. That's why I share it. (y)
I'm bad at everything, but stuff I have to do anyway, or stuff I like to do, I just keep doing until it's good enough to get the job done. ;)
Through the years we were racing, I had two air-cooled chargers set to 350 V and 6 amps (not adjustable) which would charge the battery as two half-packs. This was all we had available at the time, and it worked, but it was clumsy and if one charger stopped working, you had a long day ahead of you.
The new single charger is rated to 800 V, fully adjustable y CAN control, and will charge the 12.5 kWh battery in a little under 2 hours from empty. It's far more compact, but it is liquid cooled, and that means more stuff to incorporate into a complete system.
However, as this will be powered from a 5-pin, three-phase socket, we would often use the other two phases for things like tyre warmers, laptops, 12 V auxiliary battery charger, kettles... typical trackside entertainment. So I thought, why not combine the bike's battery charger with the GPO distribution and make a single unit, which also doubles as a coffee table!
L1 - main charger (32 A RCBO)
L2 - two double GP outlets (16 A RCBO)
L3 - one double GP outlet and all the 12 V stuff - pumps, fans, auxiliary charger etc (16 A RCBO)
You know you are seriously slacking (insert joke about broom and sweeping) I have to ask, doesn't that charger get a tish warm?
It does, but that's why the liquid coolant pump and radiator is there. I'll just use water, so if it does spill it's no big deal.
I'm thinking about putting a clear PVC cover on the last remaining side, mostly just so you can see if coolant is leaking. I'd want to do a neater job though.
And it's done. I had thought about using a second Meanwell power supply for the 12 V stuff, but the 350 W 12 V power supply from Hobby king puts out 25 A at 13.8 V, which is enough to charge the auxiliary battery to practically full and run all the 12 V stuff in the box.
Also, the three phase supply provides 7 kW to the main charger (32 A RCBO), four power sockets (20 A RCBO), and a double power socket plus the 12 V power supply inside (16 A RCBO).
Of course I'll have to get a sparky to test and tag it before I get to the racetrack. Because, make-work :)
The charge lead bundle will include the HV DC for the battery, a 12 V supply to top up the auxiliary battery, and an enable line, which will tap into the onboard BMS. If a cell goes above 4.2 V, the enable line is cut and the charge is stopped.
Nothing special - just happy I got the charger to work on a 32 amp supply. Got a steady 20 A, 12 V supply to charge the auxiliary battery, and an enable line which can be interrupted should the BMS detect a high cell. 7 kW charging means just under 2 hours to full (edited bad math).
I hope to have a BMS master control unit in a few weeks time (it will also be used on the eCRX project). Then we can go racing!
Hi Chris,
Do you know off-hand what the dimensions of that pack are? And did you place the contactors inside the pack? This is probably all posted somewhere but the thread is too long to go back very far! Well, okay, I'm a bit lazy too. :)
Hi Chris,
Sorry Frank, I missed this post from 5 months ago. 660 mm tall, 324 mm wide, 223 mm deep.
Hi Chris,
I’m new to this forum, my dream has been to convert a 2005 R1 to electric, I’ll look forward to reading this thread, I’m in Perth also, have you ever looked into making the bike road legal? I wasn’t able to import a bike from overseas so I was guessing you couldn’t put a bike you made over the pits either 🤷‍♂️ at the moment I’ll just have to stick with the 2009 R1 😊, thanks Dave
Hi Dave,
No, this bike is definitely a track only machine. Your knees are up around your ears, the seat is rock hard, it's got the turning circle of a novelty cheque, and no kickstand.
It's actually not that hard to take a converted bike over the pits - you still follow NCOP14 like any other light vehicle. If I was building my own road bike I'd pick a much smaller motor (nobody needs 230 hp on the road) which would free up more room for batteries.
Cheers,
Chris
Hi Dave,
Cheers,
Chris
Hi Chris,
My current bike has 180hp and is way too powerful can’t imagine 230, I think I would go for something around the 150 mark! Maybe it’s time to sell and start looking for a donor bike! Thanks for the advice!
Today Rod tested the new BMS brain and it appears to be working! Might be a year overdue, but at least we're going to be track testing soon!
I like the individual LEDs on the BMS boards. Like the old Ping BMSs. What model are those?
Yeah, and despite the transparent case, I can still only see half of them because they're double-stacked!
Rod Dilkes runs a business called EV-Power, he's based here in Western Australia. His original cell-top BMS designs are still used around the world but they're only suitable for low pack voltages. This BMS is about the fifth iteration of his distributed module BatMon system. LEDs light up to indicate they're balancing but he's never had a system with this many cells in series - Voltron has 168 in series.
it would be good to see this one at the track again and beat the ice bikes after a full circuit race
I suspect we'll be less competitive now that we've got extra weight and we're down on power, but would be nice to complete 10 laps trouble-free.
less power but able to complete all the laps is still good but it sure did go well before, how well did you go at the electrikana in Perth Chris ? my brother now has a Zero and my other one went there with his Tesla, electric power sure is making progressWhatsApp Image 2025-03-18 at 15.36.38.jpeg
Was a good event - Shame Ron couldn't bring the Zero SR/S to the show.
