Through the years we were racing, I had two air-cooled chargers set to 350 V and 6 amps (not adjustable) which would charge the battery as two half-packs. This was all we had available at the time, and it worked, but it was clumsy and if one charger stopped working, you had a long day ahead of you.
The new single charger is rated to 800 V, fully adjustable y CAN control, and will charge the 12.5 kWh battery in a little under 2 hours from empty. It's far more compact, but it is liquid cooled, and that means more stuff to incorporate into a complete system.
However, as this will be powered from a 5-pin, three-phase socket, we would often use the other two phases for things like tyre warmers, laptops, 12 V auxiliary battery charger, kettles... typical trackside entertainment. So I thought, why not combine the bike's battery charger with the GPO distribution and make a single unit, which also doubles as a coffee table!
L1 - main charger (32 A RCBO)
L2 - two double GP outlets (16 A RCBO)
L3 - one double GP outlet and all the 12 V stuff - pumps, fans, auxiliary charger etc (16 A RCBO)
