EcoForumZ
- Joined
- May 20, 2008
- Messages
- 83
For those of you with holes in your ezip motor I found a solution to keep water, dirt, and other bad things out of the motor and make it look cool at the same time. I found a K&N filter that fits perfectly, is water resistant, and can withstand up to 230 degrees. From my testing my motor running 42 volts has never reached more than 150 degrees and it does not have holes in it yet. My tests also revealed that the front of the motor is the place that needs the most cooling.
I purchased my filter directly from K&N website and got it the very next day!
Model # SN-2580PK
URL of filter - http://www.knfilters.com/search/product.aspx?Prod=SN-2580PK
Here she is... What a beauty!
Model # SN-2580PK
