I think that I may have damaged my new 72V KEB controller. - For my xm-4000 li erider/xtremescooter/zap.
When i got it, i connected it to a PSU like they do on the website, no
problem. I programmed it to 3 wire pot throttle(Is that correct?), and
configured everything else. Then, when it was ready, i disconnected
it, connected it to the bike, but it did not respond to throttle, and
did not give any error code. Only the green light.
Then I hooked it up to the computer again, with main contactor off,
and pre charge resistor off, and tried to connect, but the program
would not let me connect this time. Then i tried hooking it up to the
long separate wires (red and black) and give it 22 volt. Then i saw
the red light flash for ~0,1 second, and nothing happened. So i hooked
it up normally again. It
didn't say in the manual what the two wires are for, so i thought i
could connect it that way. I think maybe the two wires are for
external error code read out = connected directly to the red diode. Am i right?
So have i now destroyed the controller, or just the lights?
Do I have to disconnect motor and hall signals also when trying to connect to computer?
