The plan is to take a 2004 Kona Stinky (size large) frame,
and use the smallest of the BLT series motors from Golden Motors, the BLT-500, to drive a free-wheeling crank set up.
I'm using a freewheeling crank set-up from sickbikeparts.com and miscellaneous sprockets/parts from staton-inc.com.
Optimally, I'm designing this bike as a pedal-assist running 10s lipo and a fun, pedal-optional toy running 20s lipo. I'm using a 72v, 40amp controller from ebikes.ca and can switch my planned Lipo pack (4 x 5s 8000mah zippy packs) from 10s, 16ah to 20s, 8ah by swapping a connector plug. Early testing suggests that I should be able to run on 10s (max of approx 1500 watts) pretty much continously, where running the 20s (peaks of around 3000 watts) will need to be intermittent. I'll be adding a temp sensor in the near future before I push the 20s limits.
