Interesting/odd. Can you provide the voltage and wattage when riding at WOT when C5=8 vs C5=10?If I try c5=9 or 10, my speed drops between 22mph and 24mph.
C5 = 8 is pulling roughly 950wInteresting/odd. Can you provide the voltage and wattage when riding at WOT when C5=8 vs C5=10?
Seems like maybe you're battery isn't keeping up. The reduction in speed compared to 26mph is proportional to the voltage sag that you're seeing. What are your battery specs and how old is it?C5 = 8 is pulling roughly 950w
C5 = 10 is pulling roughly 600w
Both voltage dropping from 54v to 49v
It's off my Super73 ZX. I've had it 12 months and I had done 900 miles on the batterySeems like maybe you're battery isn't keeping up. The reduction in speed compared to 26mph is proportional to the voltage sag that you're seeing. What are your battery specs and how old is it?
Assuming it's the stock pack, it has 5 parallel groups of unknown cells. You're asking it to provide a lot more power than it's designed for (750W/1350W peak or 16A/26A peak). If you're running full throttle with a 35A controller, it will probably die soon anyway (5v of sag at 600W is a LOT). I'd spend some time researching a more appropriate replacement pack for your controller and motor.It's off my Super73 ZX. I've had it 12 months and I had done 900 miles on the battery
The pack should be good for 40A when new with those LG cells. The motor will run at around 2/3 of the rated speed when run at 48V.These are the cells in the Super73 ZX pack
