Hi folks!
I've bought a KT 36V tubullar controller (julet plugs) kit with LCD4 display and PAS sensor. Paired it with AKM 250W 100 CST hub motor and Wuxing 108-2 thumb throttle.
Thing is, when I had connected it for the 1st time, it run for few seconds, and then stopped reacting to throttle input. LCD4 display started showing empty battery bar, yet full battery pack voltage. Motor stopped running ofc. PAS doesn't work as well. I can go through every setting of the display and so on, reset it or whatever. It changes nothing, still won't work.
Seller sent me new 1-2 cable and new LCD4 display. Same story, plugged everything, it run for 3 or 4 seconds, motor shut down > battery bar went from full to zero. It doesn't run anymore. I've tested at least 3 different battery packs, same story - it shows correct voltage, yet it states they have no charge.
I've tried different controller with those parts, and still have the same problem. It's like the display gets fried or something after using throttle... WTH?
Any ideas?
Any ideas?
