ZeroEm
Mine healed and don't have any lasting pain. Good luck!
j bjork said:... I won my class![]()
It dosent look like much in the pictures but I can assure you the bike and I was rather muddy :wink:
j bjork said:At today's ride it was clear that more work was needed.
I had very noticeable bearing noise from the motor..
I took the pcb off, but left the plastic holder untouched to not mess up the timing.
Notice the washer under the screw in the middle, I think it is meant to be centered..
End covers, both were a bit wet (the bike was just washed)
On the front cover it was clear that it was not the first time, a little corrosion on the alu and more on the bearing![]()
This didnt look to nice:
The seal was not in place properly. Still surprising how much dirt got in![]()
This is how it looks:
The brown on the rotor is just dirt. I guess that it got there trough the bearing ?!
I think I will leave the rotor where it is.. The magnets are really strong, it seems really hard to get it out.
Doing so will probably do more damage than good.
Btw. I wondered how they were able to fit a 138mm rotor in a relatively small shell![]()
They didnt. The rotor is 85mm, the stator is 138mm outside dia.
