exactly, that is why i use them as on board chargers for most scooters i rebuild as they are small and have active cooling. set voltage and forget.john61ct said:That line is current limiting too, in case they pull over 40A
flippy said:why not simplfy the whole setup and use a HRP-300-7.5?
no need for resistors or whatever, just straight into the caps
So, check out the Mean Well datasheets.ElectricGod said:The SE series shut off if you over load them. Is that what you mean by "current limiting"? OR does the HRP series actually cap current and keep on running?
ElectricGod said:OR does the HRP series actually cap current and keep on running?
That approach would be suitable for stuff that is not potentially dangerous like ultracaps or Lipos, but in this case I have to raise theElectricGod said:I've put lots of stuff in series and they work OK.
There are a few false assuptions here that I need to address:ElectricGod said:In the case of the super cap boards, each board acts like a voltage divider. It is possible to get a bit more voltage at one board vs the other as it is unlikely both boards will produce the exact same resistance or load. However, as long as each board is more or less close to a reasonable voltage, they should both be OK. 8.1v per board is pretty ideal, but lots of people run them at 11.1v. As long as I stay under that voltage per board it should be OK.
Yes you did that, but on the other hand you also keep saying that lots of people would use these capacitors at higher voltages without problem. And you post pictures of your setup. I'm afraid that some may miss the point and copy that, and eventually expose themselves to danger. That's why I need to keep raising warnings against this practice. It's fine to experiment with this by yourself as you are the only one who is responsible for yourself in the end, but I kindly ask you to stop posting the results of this in this kWeld support thread.ElectricGod said:When I posted about testing to destruction, I did post several warning messages in big red letters. I think I was pretty clear about NOT doing what I did. Most people are going to see that post and already be unwilling to try this out. The people that aren't paying attention, don't know what they are doing, etc...well maybe they will see my post and be more careful before they have an accident.
That's 9.44V and way above the rated kCap voltage. This Meanwell PSU is not appropriate for kCap, and must not be used.ElectricGod said:This is the lowest the Meanwell PSU will go. Still not high enough to be a significant problem.
HMT_01 said:Hey ElectricGod,
Just one additional reminder or warning.
These Maxwell Supercaps contain as you know some nasty chemicals. What you might not know is, if you overheat the Cap to arount 150°C there is cyanid created in the Supercap. I don't think that you want to have cyanid in your house so I would look for a very well ventilated spot to overvolt my Supercaps or just stick with the correct voltage.
tatus1969 said:That approach would be suitable for stuff that is not potentially dangerous like ultracaps or Lipos, but in this case I have to raise theElectricGod said:I've put lots of stuff in series and they work OK.![]()
flag again and strongly discourage from doing this. Please don't treat this as an offense towards you personally, but as this is the 'official' kWeld support thread and a lot of other users/customers read the information posted here, I need to address this to keep others from attempting to experiment with this system like this. Trying out things in order to see if it blows up or not should not be encouraged in any way. All others: please follow the manuals for these components closely. The kCap modules may not be put in series without additional balancing circuitry. Do not charge them to more than 8.1V +/- a few percent. The maximum ratings may not be exceeded at any time.
- yes, this forms a capacitive voltage divider, but you may get significant unbalance that would lead to overvoltage of one of the two boards.
- it is not resistance (ESR) variation that causes unbalance, but capacitance variance along with activity profiles of the integrated balancers, as well as variation in leakage current of the capacitors.
- Looking at the datasheet of the used BCAP0310-P270-T10 capacitors shows a capacitance tolerance of +0 / -20% and a leakage current of 0 to 0.45mA. They don't specify a maximum initial capacitance which makes things even worse. 20% less capacitance basically translates to 20% more voltage across the two modules. This is a theoretical situation as it would only happen when one of the boards is old and worn out, and the other is new, but just to show the relationships. Voltages in a capacitive divider distribute reciprocally to their capacitances (rule of thumb), meaning that the capacitor with 20% less capacitance will get 20% more voltage, or 9.72V. The other, even worse issue, is leakage current that discharges them slowly. If that differs just a little bit, then over time one of the modules will gain more and more voltage (the one with less leakage), whereas the other's voltage will drop. Both effects lead to overvoltage of one of the modules, which must be avoided.
- 8.1V is the maximum that must not be exceeded. You keep saying that lots of people run these Maxwell capacitors at 11.1V. Can you post some links that shows evidence of this? This is unheard for me, and it would be very dangerous to do so.
I'm definitely of the first category. I deliberately never purchased a motorcycle because I know that I will drive myself to dead very quickly.ElectricGod said:Perspective is everything...
Not risk adverse:
Colin Furze...
https://www.youtube.com/watch?v=s4QBhNkaAk8
https://www.youtube.com/watch?v=LDM9aXVAoOw
Risk adverse:
Sloooooooow drivers...
https://www.youtube.com/watch?v=hnml1rxiyIw
Guess which one applies to me?
They help reduce resistance and increase current, but the inductance doesn't change and therefore the system's current limit. These are actually also longer, 650mm instead of the stock 400mm.flippy said:does the thicker leads also help with the cable length performance
flippy said:can you make a model of those handles so they can be 3d printed? i got some high temp filament i would like to try on this application.
The module does balancing, but it does it in a way that it equalizes the voltages across the capacitors (within a few ten millivolts). It does *not* limit to a given maximum additionally (I didn't see a point in adding this because a limiter wouldn't be able to fight an overvolting 50A+ charger anyway). So the balancer wouldn't complain about all cells being overvolted by the same amount, as long as the voltages are distributed evenly.ElectricGod said:As a side measure, something that I have assumed is that all the caps are charging to the same voltage and actually balancing. I don't really know if that's true or not.
Sure, let me see first how they perform. ElectricGod's remark that they may just extend the use time might be true, maybe a different material would be better. These tubes are made from 90mm long teflon rods (20mm dia) with 10mm center drill, and another 10mm drill into the side for the set screws. Then I sharpened one end with a grinding machine.flippy said:can you make a model of those handles so they can be 3d printed
tatus1969 said:The module does balancing, but it does it in a way that it equalizes the voltages across the capacitors (within a few ten millivolts). It does *not* limit to a given maximum additionally (I didn't see a point in adding this because a limiter wouldn't be able to fight an overvolting 50A+ charger anyway). So the balancer wouldn't complain about all cells being overvolted by the same amount, as long as the voltages are distributed evenly.ElectricGod said:As a side measure, something that I have assumed is that all the caps are charging to the same voltage and actually balancing. I don't really know if that's true or not.
