That is ok for slower casual welding, but you should watch the connector's temperature while doing that.if i can use a XT 90 connectors instead of xt150
As Hobbyking is often out of stock on my recommended Lipos, I've bought and tested a few more models. I can recommend these two:
Turnigy Nano-Tech Plus 5000mAh 3S 70C Lipo Pack w/XT90 (calibrates at 1570 amps when fully charged)
Turnigy Graphene Panther 5000mAh 3S 75C Battery Pack (calibrates at 1520 amps when fully charged)
Unfortunately, as of writing this, also these have gotten out of stock... My order was just a month ago.
My Turnigy Graphene 5.0 4S 75C lipo ripped itself apart when trying to weld a 0.15 nickel 0.20 copper sandwich.
Apparently it’s not recommended to go above 3S because the higher voltage of a 4S battery makes the battery work harder for the same weld as a 3S battery; which becomes a problem for thick welds that demand higher joules to complete.
I don’t remember the interesting specifics off hand, so maybe someone else can speak to that, but (correct me if I’m wrong) it’s something to do with the weld (resistance weld) being performed by current, not volts, so higher volts isn’t very useful, but is stressful.
If a weld needs 1600 amps, but the battery providing those Amps is several Volts higher because it’s a 4S instead of a 3S, the total Power rushing through the battery terminals and kWeld power rails will be higher and more stressful to the conductors (in my case the pouch cell tab conductors are what failed).
The weld just cares about current, not volts. Higher volts means more power flows through the conductors during a weld, stressing things out.
If you want good, solid professional test results of all the most popular name brands of Lipos, go here. The table on page on is always current. Another round of annual testing is not far off.You should try to recommend the Maniax lipo. Perhaps test. They are proving very powerful in the hobby field. Very good at 1mOh / cell for the 5ah cells.
ManiaX Power
ManiaX Power. 2,635 likes · 5 talking about this. ManiaX Power is a professional Lipo & LFP battery products manufacturer & exporter since 2005.www.facebook.com
Yes and you can even ask Wayne or MSCGuy questions personally and they will respond certainly. On how Wayne made that system to test those packs.If you want good, solid professional test results of all the most popular name brands of Lipos, go here. The table on page on is always current. Another round of annual testing is not far off.
Battery Load Test Comparisons - RC Groups
Battery Load Test Comparisons Batteries and Chargerswww.rcgroups.com
I looking for the same handle you use on Aliexpress, do you recommend me it ? how is the loose in all axis ? and how is the Heat at 60J when you spot every 2~3 sec ?I managed to update my welder.
First I had a 11.1v 260ah lipo that I used as main power source. This battery gave 1500a currents when charged at 11.1-11.2v, never went higher.
Now with the supercaps and the new wiring the story changes.
I get 1500a when I charge the supercaps to 5.5V. I tried higher voltages(from 5.6v to 8.1v, I didn’t charge more the caps)only for the calibration where I get 1800a and overcurrent alarm.
As a short test I tried to weld 0.15Ni + 0.1Cu to a 21700 cell using 30J. The weldings were always consistent.
I still have to wrap the caps in a pvc heat shrink and fix the welder to the block but overall I am very glad of the outcome.
I went with the supercaps because the battery was way too heavy and bulky to carry around and also enough dangerous!
Thanks Frank for the recently sent kSupply.
One small question, I know for sure that at with the caps at 5.5v my welder gives 1500a.
If I set the undercurrent protection to 1200a the welder gives an error without doing the weld.
If I lower the the value to 900a it works.
Same thing happened with the battery too.
How can one properly chose or calculate this value?
I dont suggest anything yet, I'm learning and day by day know more on that topic, I compare the results with Kweld and others semi-pro and pro weld and finally I realize how much the Kweld is not efficientFoujiwara Wow what welder do you suggest. Dual pulse ?
What i suggest yet it's the Dev of the Kweld offer to users of Kweld a new Firmware to add some features, it can be a good start, after i looking some stuff seem interesting, interesting for Current capacity, with Caps/Mos typology, but seem to dont have much fonctions, just one time duration time adjustment and the voltage of caps who will directly affect the currentFoujiwara Wow what welder do you suggest. Dual pulse ?
I'm interested in having only the base board of kWeld Pro, since I already have capacitors like the pictured ones.My intended price tag is around 1000€ for the prebuilt base unit. Power supply and output cables are extra items. I also have the idea to offer the base board for people wanting to mount their own ultracapacitors (actually kCap will also work with the new unit), but I'm not fully sure. I estimate 3 to 4 months of development work on this, mainly software and steel enclosure, but I have parts already here to build the first 100 units thereafter. These will be prototypes, and international product certification is on the list after these.
Ok, lets hold our horses now.I just bough a Kweld complete set, and i am little bit disappointed
1- Kweld doesn't have basic On/Off button or Input for that, for Turn off the welder it's need disconnect the main power line, it's a bit crazy, add a switch for disconnect the logic power supply Cost 0$ more or energy to do at the dev time
2- the software is so basic, really basic, he doesn't have two or three pulse configurable as all semi-pro or pro spot welder machine, after buying it i searching why the pro machine have two or three pulse, Even Capacitors/mosfets based units, because with transformer it can be logic to follow the AC, but it's not only for that and it's useful i explain more down.
3 -Kweld complet set are just not able to spot repeatedly without overheating, after less than ~15 spots it is already impossible to hold the Pen and all the cables are so hot, and with just ~50 Joules (it mean, he loose so much energy in the line when it should be in the solder point) 8 Awg is soo bad choice, 6 is better but still too weak
4 - it's limited at 2000A (one guy said at 1800a he already get the Alarm) when for less than that price you have Capacitor based spot welder complete can go at 1800A for around 180$ shipped, and up to 6000A for some Serious one around 500$ with Capacitors/mosfets typologie, i never try it because many ppl pull up the Kweld as the best but so i dont feel it when i use it ...
so, considering the necessity to bough the Kweld at ~210€ Shipped + Buy Separately Another Handle, Another Wires bigger, and Bough power supply As multiples big Lipo or Capacitors and considering the others points, the fact that need to re-set the energy we need at every start, because every time i disconnect and reconnect it come back to 10J ... so yeah, i am a bit disappointed, I've been too hype by my friends and by random ppl on internet and finally I'm disappointed, it's neither a semi pro tool even less pro, it's good to spend a days spotting a battery, and sip a drink every 10 spots for the let cool down all the Kweld Set, and not get the best spots because of the lack of the multi pulses and because of the low current capacity also, in my case it up until 1300~1400A at best, and it's enough to be impossible to use after some spots as i explained
for the multiples pulses adjustable :
"Professional spot welders often use two pulses instead of one for several reasons.
Firstly, using two welding pulses allows for better heat control and minimizes deformation of the parts being welded. The first pulse establishes the electrical contact between the two parts being welded, while the second pulse provides the energy necessary to create the weld. By using two distinct pulses, the amount of heat applied to the part can be better controlled, reducing the risk of deformation or damage to the part.
Furthermore, using two pulses can also result in stronger and more durable welds. By using the first pulse to establish electrical contact, the second pulse can be used to create a deeper and more homogenous weld, increasing the mechanical strength of the weld.
Finally, using two pulses can also help reduce spatter and splashes during the welding process, which can improve the quality of the weld and reduce the risk of defects or damage to the part.
In summary, using two welding pulses in professional spot welders allows for better heat control, stronger and more durable welds, and reduced spatter and splashes."
I saw the images of the KweldPro which will come out around 1000€ for the Pcb only, it uses the same number of Mosfets than the Kweld and the same typology as the curent Kweld, it just integrate a screen and additional capacitors, it is not necessary to have a screen to have fonctions more complete & versatile software and to integrate functions such as multi-pulse, can you already offer to your customers a firmware update ?? in order to be able to at least :
1- get the multi pulse (3) configurable in Joule per pulse and delay between pulses?
2- have a standby mode if you can't turn it off without unplugging it, if we can turn off the screen it can be a good start (can be turn off the screen automatically after inactive time also (but maybe you dont have circuit to control the backlight ..)
3- increase the memory management, that at least it keeps the preferences after power off
View attachment 333017that Parts totally useless, i stop to use it after less than 20mn when i realize how useless it is
View attachment 333018i modify the Box to had a fan on it, if someone are interested i can share the STL
View attachment 333019my temporary installation, with Free recuperation battery and temporary handle too, it's friend who gave me it but it's shit too, it heat less than the handles in the complete kit but still too much and it have A LOTS of loose, i looking for something else but i am not sure wish one yet, i dont want buy again for something and be disappointed
The unit will come with a 450W power brick (18V / 25A), but you can also operate it from a battery. The onboard ultracap charger is designed for 60 amps, and that should allow for 200 Joules per second at the output terminals. The cable losses will reduce this, but for copper one could use massive ones.
Hi Allex, Thx for your answer, your test with the internal view of the Cell is interesting !Ok, lets hold our horses now.
First of all, what is this in the red ring?
What I see is a thin wire that is Soldered to the cable shoe in one and then soldered to a plug on the other end. Then, it is soldered again before it goes to a wire. There is so much losses in this connection that I dont even want to imagine. Alway crimp your connection when you are handling kiloamps.
I use a 2s3p battery out of a VW golf module with crimped 6AWG wires. The unit never overheats and wires are just warm when I am doing a battery out of 90 cells.
Second. Your welds are way overheated, you can see it by halos, dark melted spots around the spot weld. A properly dialed in welder with a good battery does not need more than 25 Joule to operate and do perfect spotwelds. Here are some pictures for reference on what happens on the other side of the can if you do too much power with 0,2mm nickel.
You can see the joules marked with red marker. See how clean they are:
As you can see, at 55/65 you begin to melt unnecessary metal rather than weld.
Lets cut a cell in half and see what happens inside:
So lets turn the cans, first one is 20 at the top and 25 at the bottom:
Second is 35/45 at 45 you already start do some damage.
And last is 55/65 well, here you can see that it is excessive
So my welds are good enough at 25J without too much damage to the internals. Of course with different batteries you need to dial different J to get a weld. But this is something to think about. I do also own three 2 pulse welders, but I prefer kweld over the others.
Oh yeah, Pro tip - never weld in the middle of the negative can as you have negative tab attached there.
i will be able to say it soon, my friend ordered that one today, after we had again some issues with the Kweld xD like two spot literally at 5 secondes between both, same power, same everything, the first was weak and not soldered and the second make hole in a cell...Any have a comparison between the kweld and us solid(or capacitor based) spot welders? Wanted to make a pack with copper sandwich method.
for me it's not true, it good approach but it can't eliminates the need of a cleaning pulse, why you did not implemented the cleaning pulse ? it's just a bit of code linesUpdated schematics (rev.1).
I plan to implement an energy based pulse control instead of a simple timer. i will try to see how that works with one single pulse, maybe that eliminates the need of a cleaning pulse. Constant energy delivered to the weld spot should result in more consistent welds. The circuit should also be able to detect a failed weld, in this case the requested energy cannot be delivered in a reasonable time.
What do you think about this approach?
Yes I would like to see that. How long till u get it? Most stuff from aliexpress.com take a month to get to me. I usually try to by local vendors.i will be able to say it soon, my friend ordered that one today, after we had again some issues with the Kweld xD like two spot literally at 5 secondes between both, same power, same everything, the first was weak and not soldered and the second make hole in a cell...
i am happy, soon we will can compare really if that spot welder is really 6000A, how it work, and how it's made inside
It shouldn’t be the case but it works like that.does this mean that you don't get a double beep error when you set "MinCurr" like this? That shouldnt be the case!
60j every 3s means a lot of heat which requires to optimize a few things.I looking for the same handle you use on Aliexpress, do you recommend me it ? how is the loose in all axis ? and how is the Heat at 60J when you spot every 2~3 sec ?
Big one, until 6000A on the description : https://fr.aliexpress.com/item/1005005236651955.html?gatewayAdapt=glo2fra
Small one, until 1800A on the description : https://fr.aliexpress.com/item/1005...=20230421043659187430526716500003872651_1&s=p
but i never test it, i can't confirm if it's well or not and if the description is true
generally something between 1 week to 1 month depending of lots of things, let's see when we will have itYes I would like to see that. How long till u get it? Most stuff from aliexpress.com take a month to get to me. I usually try to by local vendors.
hello guys, sorry for the late reply but I didn’t get the email notifications from here.
You will need thicker wires between the welder and the pen also between the power source and the welder.
The electrodes that come with the welder have the bottom part pretty thin which makes them heat and stick to the nickel even at 20j.
You will need to cut entirely that part and adjust the tip accordingly.
To make the electrodes heat less you will need to push them out under 1cm. Less you pull them out less they heat up, the current is higher and the weld is better.
I bought some tellurium rods but didn’t feel the need of using them until now.
There are 3 pen versions from which 2 have air or water cooling. So choose wisely.
The play of the parts inside the pen is close to nothing.
The part that I like most about the pen is I don’t experience anymore blown holes in the strips which I encountered now and then with the original pen because of my shaky hands and a bit of fear every time I did a weld.
Now I can’t recommend nothing to nobody, sorry.
I shared my findings and my suggestions on how to make it work. It’s up to you to decide if it’s worth it or not.
