kWeld - "Next level" DIY battery spot welder
Anyone local to San Francisco who can fix these? I have two I’ve broken by contaminants getting in and shorting it. If u fix one u can keep the other.
I’m also desperate to borrow a welder to weld six cells to finish a battery.
What kind of contaminants and under what circumstance did the short occur?
edit: If contaminant was water (salt water the worst), probably not worth trying to repair. If you shorted out the power FET's or diodes, those can be identified with a DVM and replaced (if you can source the same quality parts).
I’m not sure exactly what it was that did it but something slipped passed the kapton I had it wrapped in
