Hi,
Long story short.
Bought motorcycle style motor, custom made. Spoke holes are Ø4,2mm in diameter. Going to lace in bicycle rim. Ordered to length 13G spokes.
I want to do this somewhat the right way.
Problems:
1. Spoke hole too big, nipple falls through
2. Spoke "neck" too short in comparison to hub flange thickness.
Identified solutions:
Easy way. Brass washers to keep the spoke in the hole. Absolutely fixes problem 1. But what about problem 2?
Hard way. Lathe away some of the hub flange to make suitable thickness. Brass washers to keep the spoke in the hole. Fixes both problem 1 and problem 2.
Hard way 2. Drill new ~2,6mm holes in hub flange. Use oversize drill to thin section down to suit spoke neck length. Solves problem 1. Solves problem 2.
I've added some photos to illustrate.
Long story short.
Problems:
