Stephen Jones
S-LCD3 Parameter: Alternative setting for the following setup
Spec Motor: Bafang 500 watt BPM2 CST (09) -
11.6AH Bottle Battery 09 rated at 48v including the controller. Incl inbuilt BPM cell Panasonic NCR18650PF (3.6v) Configured as 4 Parallel, 13 Series
S-LCD3 Display includes the Programmable Controller
The kit was simple to install and worked on arrival a kit supplied by BSMBATTERIES, The kit included feature to aid the installation adopting colour matching for matting plus and sockets, Plug orientation was indicated with a simple arrow.
Although there is a manual available, the instructions don’t explain in sufficient detail the reason the programming values are required or were to obtain it from, which led to difficulties in programming the S-LCD3
The following setting were used, based on the following understanding,
Speed Max - 55Kph
Wheel Size 28"
Unit - Metric
P1=80 5:1 internal hubs gears x No of Magnets 16 (See Motor Specification)
P2=6. The number of Electrical Pulse outputted by the motor per revolution (See Motor Specification "Cadence Value")
P3=1. 1= Torque Assist and 0 = Speed Control
P4=0. 1 = Throttle Control is applied when peddling. 0 = Throttle control is available from a standing start
P5=12 Power Monitoring Mode" i.e. battery capacity determined, Values =0-40, with 0 being real time voltage. 36V use values typically 5-15,
C1=2 Crank Sensor Magnet count 1=8 2=10 3=12 (Count the number magnets on the crank disc)
C2=0 C2 Motor Class for a Sine Wave controller is VALUE the DEFULT = 0
C3=8 Initializing mode of Power Assist gear ratio values 1-8 Meter is switch on C3=0
C4=0 Affected by P4 Handle Bar Start up modes
C5=9 Controls the demand for Current AMPs. I.e. 90% 10=max
C6=4 LCD Backlight
C7=1 Cruise Control On= 1 off = 0
C8=0 Motor Temperature Read only available if a sensor is installed On=1 Off = 0
C9=0 Power On Password Default = 0 Reading from Left to Right, range 000-999
C10=N Y / N to establish default setting
C11=0 LCD type setting LCD3=0 , LCD1 or LCD02=1 copy function =2,
C12=4 LVC (Low Voltage Cut out) value use to protect the battery and calculate the Power left in the Battery
C13=0 ABS and Energy recovery
C14=2 Power Assist Tuning is invalid if P3 = 0 if pedal assist is required Set P3=1 High = 1 Medium = 2 Low = 3 assist
Please note these values did ensure the speed and distance was measured accurately, but did not make the Pedal assist functioned.
The bike used the thumb accelerator and the Cruise function.
(I proffered to use the cruise control in favour of the Peddle assist, in using the cruise control you can effectively increase to range of the bike by reducing your speed. SIMPLE use the throttle to the desired speed and press the "the Arrow on the switch for 5 seconds and release both the Button & then the Throttle" viola you in cruise mode.
Battery Capacity currently shows full even when empty. Possible due to poorly calibrated or defective Voltmeter
(Any power you add by peddling will increase the overall power output of the bike, this can be as high as 1300 watts a value confirmed by STRAVA)
Its also possible to set the Max speed at which battery power can be consumed. By doing so its possible to increase the range of the bike. ie Setting the Max 30KPH
Battery Power Usage: E-bike Users are acutely aware of the power remaining in their Battery.
Ensuring we get to our destination with assistance.(Peddle home with an empty battery is no fun! although surprisingly easy for a 22kg bike, a feature support low resistance free wheel.
Noise: The Bafang Motor BPM2 500watt created low level of noise and resonance compared with MAXUS 250watt motors. In fact i frequently startle pedestrians and cyclist
At slower speed to power was applied more smoothly.
Here we describe the use S-LCD3 Parameter Setting C5 ONLY
C5 setting gives you the capability to reduce the max power being pulled from the battery by up to 50% which will increase the range the bike will travel per charge.
In this instance the Bottle 09 Battery (48V 11.6AH) can delivery 850watts when C5=10 or 350watts when C5=3
When C5 is set low the bike range will increase but does affects the torque and speed.
BPM2 500 Watt Motor example
C5=3=300watts (Distance 70Km at 30KPH)
C5=4=400watts
C5=5=550watts
C5=6=600watts (Distance 50Km at 40KPH)
C5=7=750watts
C5=8=800watts
C5=9=840watts (Distance 35Km at 50KPH)
C5=10=Max POWER 860watts
C14, C3, C4 require validation.
Please note BSMBATTERIES, sell these products but there Technical Support is a Joke once your order has been secured (in my option) product old with no written documentation. BMSBATTERIES relay heavily on forums such as these to help resolve many of these issues.
This forum is life line to those of us who are none technical!
This post will be edited as improved knowledge is obtained.
Speed Max - 55Kph
Wheel Size 28"
Unit - Metric
C6=4 LCD Backlight
C5=4=400watts
C5=5=550watts
C5=7=750watts
C5=8=800watts
