John in CR said:
Since they don't make a 2t version, the only wind I'd consider buying is a 3t, and with that I could build any low to moderate performance ebike that a customer wanted as long as they didn't want a 29er (which I'd refuse to build and would discourage 26" wheel builds, not because of the wind but because they'll get more range and better performance with a smaller wheel.)
A light-duty 16" DOT moto rim with 13ga spokes laced to a 3T version of the rear-drive freewheel-compatible Leafbike motor with a quality-built 11-34 7-speed freewheel installed, including a Mitas MC2 DOT tire(rated for 62 mph) installed on the rear wheel, would be perfect for this. Unfortunately, that freewheel doesn't exist new anymore. DNP's Epoch and its rebranded variants are crap, but that is about all there is today for a 7-speed freewheel with an 11T small ring present, and even those are under threat of becoming unobtainable. Should be good for 65 mph top speed at 72V with a powerful enough controller to drive it, although 96V would give 87 mph. 150A from the controller to this, a limit of 96V, and a 7 kW power limit would give a heavy tadpole trike set up with this an acceleration rate comparable to the average new car on the road. And the favorable part of this setup's efficiency curve would be very broad.
My cheap 46.8V 10.5AH battery arrived, and now I'm trying to source some small Andersons and XT60s so I can install them to the pack in order to charge it and connect it to the controller. With a 5T wind, setting that battery's draw to 1500W should give me around 35 mph top speed with my Leafbike motor and Phaserunner controller, which without the motor installed or all the heavy things that go with it I can already exceed 35 mph on the flat pedaling it, but the motor WILL at least be able to allow a 30 mph cruising speed, a speed which I can't currently do on the flat for very long. Hopefully the motor's iron loss and hysteresis drag is very low on my 26" bicycle wheel, since there's no point to me in it not being pedal-able with the motor off. When I have my 20S2P 72V 7AH LiIon pack built up, I will then be able to upgrade that top speed to 50 mph with the same amount of power. Then when I do the 20S6P 72V 21AH pack of the same type of cells soon after, I can increase the peak power to 4.5 kW or even slightly more!
I currently have a Schwalbe Marathon Plus Tour tire on my 26" rear wheel. It's about as puncture-resistant as e-bike compatible bicycle tires get, but I wouldn't trust it at 30+ mph. A rear tire blowout on my tadpole trike would be catastrophic at 30+ mph, let alone doing 60-100 mph, so that Mitas MC2 low rolling resistance tire mentioned earlier would provide an acceptable resistance to catastrophic failure from puncture, better than any bicycle tire, and with most of my weight being over the two front wheels, rolling resistance wouldn't be impacted too badly by adding this tire, keeping it pedalable(some testing would be needed to determine if they were of sufficiently low rolling resistance for the front). The Marathon Plus Tour's rolling resistance is not considered to be very good, and I can't say whether the Mitas MC2 would be better or worse regarding this, but the assumption is that it would be close. On the front wheels I could probably get away with 50 km/h continuous-rated Schwalbe Marathon Greenguard e-bike tires, even at higher speeds, since a front blowout would not cause me to lose control as long as the rim is in-tact and the front suspension maintains air pressure, but I would definitely want stronger rims and hubs than the quality bicycle parts I have. These tires are good enough to stop my unmotorized velomobile from 50+ mph, but I've never had to test a panic stop from that speed, for which I'd want to upgrade my Avid BB7 cable-pull brakes to hydraulic brakes(I did have a panic stop from 45 mph and the tires did fine, although the braking wasn't even because the calipers went slightly out of adjustment and getting pulled toward a minivan in the other lane was scary and required careful modulation of the brake lever to avoid going passed the red light and into an intersection with 50 mph cross traffic). With the smaller rear wheel diameter of the 16" moto rim(comparable to a 20" bicycle tire), I'd need a rear suspension installed given the condition of the roads where I am at, and my current body shell would not be able to accommodate for that OR the smaller wheel, so would require a re-design of the shell. But a 3T upgrade and a more powerful controller and sturdier rims all around with a more aero body, a lighter more powerful/energy dense battery, and a roll cage, is something I've been thinking about for the longer term for this KMX, at least in hopes of making it safe to cruise at 45+ mph, while still being pedalable with the motor off.
