jonescg
So I pose a hypothetical:
Is it possible to have a cylindrical cell leak electrolyte and still be functional?
My VOC sensor idea has got me thinking - what if a cell leaks a little electrolyte and causes the sensor to shut the bike down. You let the pack cool down, but after no more electrolyte is discovered, you charge the bike up as if nothing happened. What are the likely consequences?
I suspect that the leaked electrolyte must have happened due to 1) physical trauma to the cell case, or 2) excessive pressure build up. Excessive pressure can only happen if the internals of the cell are able to heat up because of either 2a) an internal short or 2b) an external short.
I would have thought that the cell's internal resistance would increase rapidly due to the loss of mobile Li+ ions. By sharing the currents of it's neighbouring cells, it will heat up more, causing more electrolyte to leak... and eventually turning it into a heater.
Suspect a first response should just be - remove pack, start again, keep house.
