This is my first post in the community, to hear your advice on how would you proceed from now on...
I did not custom made the bike frame, but tried to 3D model it once I received the bike in order to shape my mental design of the battery holders, the main problem wasn't having zero experience and background in the task which I don't, but to not double check all the measurements at the very moment I finished the frame sketch.
After double checking the CAD measurements of the frame and the inner triangle length, it does not match at all with reality.
Now I see the main fault was to use the manufacturer angles for my frame size instead of obeying to the angles I extracted myself taking a picture of the bike.
The battery manufacturer provided me the .step file but I regret to not have asked before having the entire modeling done, I also asked for the .step file to the bike manufacturer which I think may have no interest or it may go against the company rules, but no answer for now.
I believe I can somehow subtract volumes for each of the 3 battery holders, using the battery .step file to cut through them, and at least ensure a perfect fit between battery and holders.
The frame angles are way off and that's the very reason why I come to ask for your advice since reverse enginering may be not my thing, maybe a 3D scaner may have helped from the very beggining and I am not sure about the precision of extracting the angles with a photo and a phone app.
I spent a week figuring out how to 3D model it and I am not afraid of spending another week or whatever it takes to have a serious V1 candidate for the holders printings, but I am afraid to keep working on wrong measurements despite it sure will be a precious learning.
I would like to present the project properly on the ebike builds section as soon as having the 3D parts printed but I can say it's a beautiful one for a commuting bycicle,
It's made around the maintenance free idea, slow winding torque sensing fat DD, belt, gearbox, rigid frame/fork, 29x2.60 tires, fenders, lights and a 7kg 1260Wh 52V 40A+ automotive grade battery on Samsung 50S cells pulling 8A/cell at 30% of it's max continuous discharge when wide open throttle.
I would like to see very little voltage SAG, but let's see If by mostly cycling 20 to 80% SOC they last more than the certified 200 cycles by Samsung, well aware of the optimism labeling them as true high power cells, they clearly don't have the best IR anywhere near the 20A despite being labeled as 25A max continuous, but at max 8A draw it should be an excellent cost/efective choice,
Wish me luck
