Lebowski
Very busy coding again... I figured out how to re-capture a running motor, you can even cold-start the controller with a motor that is already running.
Main 'problem' is that I cannot test it other than with my small RC motor. The RC motor I can spin with a drill, and without feeling any type of jolt or
other force on the drill it captures. The big scooter motor, I cannot spin this to high rpm as the motor is not built into a vehicle. I can rotate it slowly
by hand while the thing is held in a vice. The controller captures this good, but the low rpm doesn't make it a valid test. Both AF motors I have
are built into bicycles and have freewheels, so after locking the wheel, when you release the brake the motor will stay still because of the freewheel.
So this is not representative of Zombiess case with a direct drive hub.
So, what I'm doing is putting all the things I think are necessary to make it work under all conditions in the controller IC, and then zombiess will have
to test and tell me whether it needs more...
