I think I figured out what is going on, most of it anyways. The new is good
With the real time data out over RS232 the controllers allow me to see what is going on, so I can see what voltages and currents they are providing. It turns
out it takes only 20W to run the motor at around 50 k-erpm. If I use either one on it's own, it wlll provide 20W to the motor. If I use both the power is split
(not equally but close, as the controllers are running different deadtimes etc etc) but the total is still 20W.
What had me stumped though was that even a single controller takes about 60W, meaning 40W is lost somewhere. An apparently with both they take 120W so
100W is lost. Looking at the power consumption of a single controller, one takes about 5W, the other about 8W (as it has a fan). So there's quite some power
lost and it's going to the motor as this gets pretty hot with 2 controllers.
And then it hit me, the motor is only 15uH (see picture above) with the PWM stages running at 21 kHz, all the extra power that is lost is due to the 21kHz currents
from the PWM ! Increasing the PWM of one controller to 33kHz immedately saved 20W, reducing it to 11kHz increased consumption by more than 25W extra.
So, one of these days I'll try to measure the motor resistances and run a simulation, see if the PWM totally explains the mysterious power loss (not tomorrow as
Holland is playing agains Australia
What also still needs explaining is why it has trouble capturing when only one controller starts....
Interestingly also, the PWM losses is a fundamental issue where a dual 3-phase is at a disadvantage w.r.t. if it were wound as a single 3-phase.
