TorontoBuilder said:
I can't concur with your thinking because I've actually done calculations rather than made an assumption.
I made the same calculations as you, based on the same assumption as you. Only to realize while the calculations were correct, the assumption was wrong...
The 30 KV APS 6374S is designed to operate at a much lower rpm so that the corresponding power, torque and efficiency curves will also be lower
--> this assumption. It is an assumption, and it's wrong.
Typically the low kV motor is the exact same motor as the 200+ kV version, just with more turns of thinner wire.
This is seriously off topic already (and the wrong forum section!), but...
sleepy_tired said:
After looking at RC motors with especially low KV ratings I always wondered what the penalty for this is.
The trade off is that you either have to raise the voltage to spin it up to the same speed as the motors faster "brothers" to get the same power, or just be content much lower power than the "rated one". Or get a bigger motor.
Make a separate thread for small rc motors with high kv, (in the right forum section) and we can go further into details. I'm quite interested in this topic also.
