Hugh-Jassman
Regular
- Joined
- Jun 20, 2015
- Messages
- 407
I have been looking for a hub that can easily be used to hold a disc rotor and a large sprocket on the left side. Or a large sprocket and a free-wheel on the right side. I want to use one of these 170mm wide hubs, I don't know which is the rotor side but it looks like it maybe the one marked. True? Looks like the other side is made for a motorized sprocket.
[EP-OSET-HB3616 For 16.0 Racing (pre 2015). Alloy with OSET logo with double disc bracket. 36H ] Has anyone used it??
https://osetbikes.com/gb/parts/pre-2015-parts/hubs/rear-hub-for-16-0-racing-pre-2015/
Building a spline cutter for free wheels would be too big of a project:
https://endless-sphere.com/forums/...&sid=5357c6879c872b961dad4c594267d010#p206163
I thought I saw a fixed gear Origin8 that had an extra storng rotor mount, but can't find it now. Just the full cassette one. But do they have large sprockets to fit? Or a large one could be bolted onto the small srocket? The small one would be better for human power, with the motor on the break rotor side. Maybe I should just use one of these adaptors and make sure the frame is wide enough for it. https://mbrebel.com/product/60-tooth-sprocket-415-41-chain-fits-sprocket-adapters-u-s/
oset hub uses 6000-2RS Bearing 10x26x8 Sealed [cartridge tyrpe] Ball Bearings
Loose ball bearings ! [disposable]
http://vi.raptor.ebaydesc.com/ws/eB...tegory=177820&pm=1&ds=0&t=1541804702000&ver=0
There is no way that I am going to build such an expinsive machine without using cartridge bearings. I had a nice shimano hub that used loose ball bearings, and was over hauling it every summer. But the local bike shop kept giving me new cones that were a bit larger each year untill they were too large and it ruined the hub. Well now I do every thing my self because I can't trust anyone. I now have a Velocity hub with excellent bearings. I always buy extra bearings because they may stop making them.
I want a 170mm symmetrical hub built that well for a simular price for my next project [something like the red bike] I'll use a BMX hub on the front. Or maybe one the new 135mm symetrical fatbike disc hubs with a 2.5” tire and 16” motorcycle rims. For 600-700lbs total combined weight I should try to find a 14mm axle hub, do they make these with more than 12mm? At least that is more than 3/8th inch and possibly a double wall axle?
I found only two that have strong enough mounts on the left side. And 17cm looks like it is made for 4inch wide tires. But I want 2.5 to 3 inch max with extra room for drive chains on both sides. I can't stand having my drive chain rub against the tires. It collects too much road mud crud.
