Legway Unicycle not starting
mithilesh
So my legway needed repair as it wasn't starting
So i ordered a new controller from aliexpress
Connected it and was excited but no
Legway is not starting
I tried calibrating by shorting the two points
It only beeps
And then a never ending long beep
I noticed one thing when connect the 3 phase wires with transparent green caps
The motor doesnt rotate freely with or without battery
When i remove that the rotor moves freely manually
It brakes every quarter turn with phase wire connected
The beep never ends
Also two days back sane connections
legway had stabilized but didnt move when tilted and stopped again immediately and since then only beeps
This is the video showing problem
https://youtu.be/NG95tXu8BFc
P.S This isn't the original legway motherboard.i dont even know the hall wires connections
But one good electronics person told me the red and black are proper
And i did try combinations for other 3
Pls help
PLS SEE THE VIDEO AND HELP ASAP
I'm not quite sure of everything you've stated, and can't see the video (probably my ISP), but if the motor won't turn freely when the controller phase wires are connected to it, but does when the motor is not connected to anything, then the controller probably has blown MOSFETs.
If the motor won't turn freely even when connected to anything else, and nothing is physically obstructing it, then it probably has shorted wiring or coils inside--either to each other, or to the metal laminations or other parts inside it.
So what's the solution
I dont think the motor has any faults because i have this
Brushless motor controller tester which shows that motor is proper
What should i do?
