I wonder what part of my setup is just not working right, because I can't really get the stopping power I expect I probably should get out of *any* of the rim brakes I have ever used, and these Avid SD5 arms I have on there are the best ones I've had. I don't have the Avid levers, though, and am using a Shimano lever meant (AFAIK) for this style of brakes.
I've done all the possible adjustments, AFAIK, and tried a few different brake shoes, with some difference in each one, but none quite good enough.
One possible issue is the cable itself; ATM it is a long cable from (I think) SickBikeParts, something AussieJester sent me, like the ones he has used successfully. The housing is a two-part housing, as I didn't have a single one long enough. I've planned (but never had the chance to try) running a cable thru very short housings to cable stops on the frame, with bare cable between the stops, which would probably significantly help the housing compression losses I get.
Another possible issue is the crappy front fork, as the bosses could be moving or pivoting around the suspension post. I tested these brakes first on the much better (but still not great) RST fork, just before and at the DeathRace, but due to the geometry problem causing the death wobble for various maneuvers, speeds, and braking, I coudln't ever really hit them hard on that fork--it might make them much better.
Given that me and the bike is about 300lbs, I'm not surprised I have trouble with the brakes, as I only have the front brakes. I tried some rear caliper style for a while, but they were just about useless, and I had to take them off for some other experiment and never bothered putting them back on.
If I could find a large enough disc brake rotor to modify into a hubmotor-cover-bolt-ring-attached rotor on the front, I'd try the large-diameter disc brakes on there and probably get plenty of stopping power.
So far, no luck in that yet (except a used motorcycle rotor that was way way too thick for my calipers, and far too big to stick on the lathe to shave it down).
