Little-Acorn
- Joined
- Oct 15, 2009
- Messages
- 130
Most LiFePO4 batteries I've seen for e-bike applications, usually have discharge rates around 1C. So, a 20Ah battery can put out 20 Amps continuously for one hour, before being exhausted. If you try to discharge it at, say, a 2C rate (40 Amps), it will do it. But instead of lasting 30 minutes as you would expect, it goes exhausted sooner than that, in maybe 15 or 20 minutes.
Hobby City (a mail-order hobby shop in China) has long had lithium-polymer batteries with the high discharge rates typical of that technology. But now they have started selling a few LiFePO4 batteries, which they advertise as having similarly high discharge rates. One set of LiFePO4 batteries are advertised as having a 30C discharge rate! And that's a "continuous" rate, its max rate is 40C. If true, this means that a 4.5Ah battery can discharge at 135 Amps. Only lasts two minutes, but that lets you get the entire burst of energy stored in the battery - it won't die before putting out its entire 4.5Ah at its rated voltage.
Examples:
6-cell LiFePO4 4.5Ah battery, 30C(!) continuous rate, $69.99:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10311&Product_Name=Turnigy_4500mAh_6S2P_30C_LiFePo4_Pack
3-cell LiFePO4 4.5Ah battery, 30C(!) rate, $39.51:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10310&Product_Name=Turnigy_4500mAh_3S2P_30C_LiFePo4_Pack
2-cell LiFePO4 4.5Ah battery, 30C(!) rate, $25.56:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10309&Product_Name=Turnigy_4500mAh_2S2P_30C_LiFePo4_Pack
Of course, no e-bike needs 135 Amps at 36 or 48 volts or whatever. That would fry any known motor, and/or twist the axle right out of the fork even with a torque arm or two installed.
But the good news is, a relatively small battery (like 48V at 4.5Ah) can be used, and will easily kick out the 20 or 30 amps the motor needs to climb hills, accelerate rapidly, etc. without the battery voltage sagging or falling off prematurely.
My guess is, a 48V 1000W motor doesn't always run at 1000W (approx. 20 Amps). When speeding up or climbing a hill, it might use the entire 1000W. But for most cruising on relatively flat ground, some riders will back off on the throttle and cruise at maybe 15 or 20 MPH, and only draw maybe 10A from their battery during that time.
Until now, someone with a 48V 1000W motor, has to buy a 48V 20Ah battery (up to $1,000 for a good one like a Ping battery) to get full performance (20 Amps at 48V) under all common conditions. One benefit is long range, since the battery is so big. But that price tag hurts.
Now, he can buy two of these 6-cell 30C 4.5Ah batteries and two 2-cell batteries, and use them in series to produce 48V Total cost is less than $200 (plus shipping), and the bike will perform just as well as with the big battery... until the battery runs out, which obviously it will do in 1/4 the time.
Has anyone tried any of these high-discharge-rate 30C LiFePO4 batteries? Are their advertised claims, true?
Examples:
