safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
http://en.wikipedia.org/wiki/Opto-isolatorGGoodrum said:...optocoupler
That's a complete topic unto itself.
I do appreciate the graphs and the validation that cells are not all alike and some behave badly. That seems like something that is pretty easy to understand.Doctorbass said:The cell 9(in light purple) is weak and also, the best cell in this pack is the cell 3 (in green)
One day we will not even open up the batteries because they will be sealed at the factory. All this balancing stuff is just to cover the gap between now and where things are going to end up.EMF said:Frankly, I think the BMS and assorted tools that can help keep a pack healthy will be a big plus for the e-bike and personal transportation category. Not to mention, help many folks get a lot more utility out of their money spent. Anything to take complication out of the mix, will help to lure more people to electric.
safe said:Haven't we agreed that charging behaves like Lead Acid in that when a cell is full it simply becomes inert and allows other cells to absorb more charge?
safe said:There is no need for charge balancing... the only critical thing to worry about is when a cell drops below it's low voltage level while the rest of the pack is still going strong. It's this first cell that drops off that will tend to age faster. So discharge balancing matters while charge balancing does not.
safe said:You guys need to learn how to "teach" better.
Slow down the ideas... try to think as if you are a beginner and you are making the path from no knowledge to the final conclusion. Thrown in some fun along the way to make it easier for a novice to enjoy the journey.[/color]
There seems to be some contradiction when it comes to issues about cycle life. If any cell is given too much charge voltage it increases it's aging rate. So because of this the charger should back off so that the voltage never rises too far and this will drop the current towards the end of the recharging process. When you do this the tradeoff is that the rest of the cells that are stronger tend to get only 85% of their theoretical peak charge.GGoodrum said:This way the SLA cells will self-balance, and each will get a full charge. Lithium-based cells don’t have this extra current “absorption†capability, so if the voltage is held at a cutoff voltage, the current will keep dropping all the way down to zero. This is a problem for cells that are connected in series because it means the slower-to-get-a-full-charge cells won’t be allowed to finish. This is because all the current that a charger supplies always goes through all the cells. If you have one cell that “finishes earlyâ€Â, and cuts the current down to nothing, that means the rest of the cells get nothing too. This results in cells that end up with less than a 100% charge. This out-of-balance condition will just get worse over time, if left unchecked. This is how cells get damaged.
But trying to handle 1920 watts worth of power in the BMS circuit is a real problem. Adding capacitors makes it easier on the BMS circuitry.Ypedal said:The amount of power required by our controllers ie: 20 to 40 amps can be delivered with these lithium cells without the need for this extra hassle...
safe said:But trying to handle 1920 watts worth of power in the BMS circuit is a real problem. Adding capacitors makes it easier on the BMS circuitry.Ypedal said:The amount of power required by our controllers ie: 20 to 40 amps can be delivered with these lithium cells without the need for this extra hassle...
