Bad news on my end.
I installed the rear tensioner and the chain slippage went away but now as a result, i have a loud chain, and i don't like single chainring mode.
I removed the torque sensor/idler and the racket was reduced, but still sounds like a broken bike.
Well whatever, i wanted to see the stock experience so i trudged on..
The power connector to the controller has been chronically loose since the beginning, and i've had to bend the pins to get a good contact again before.
This time i bent them, part of the positive one snapped.
Frustrated with this motor after all the hassle.
So okay, i'm out of warranty so i decided to take a peek inside.
The mosfet cooling solution is pretty smart. We have the controller heat on a big chunk of metal on the the opposite end of the motor, nice.
The motor appears to be sensorless. I cannot find anything on the board that looks like a hall sensor. And no additional wires out the motor.
^-- btw this capacitor is 80v rated
The motor winding has a lot of loose copper doing nothing on top, That's disappointing because it means the motor is less efficient than it could be.
Due to the position of the gears ( right above the motor's phase wires ), there is no easy way to route the phase wires out, other than to drill into this big heatsink portion shown here. to reach where the phase wires connect internally.
I am generally pretty impressed by the build quality and would like to continue using it anyway, i think an external controller can unlock some more power
I think that since this motor is very high RPM, a VESC would probably be the best driver of it instead of a phaserunner.
Let me lick my wounds, find an appropriate urethane sealant, and i'll take a stab at running this externally.
