SlowCo
Very curious what a PV Next-Gen controller and an XXL could do as a combo for (light) motorcycles. Seems a nice match when dialed in correctly.
LightningRods said:Here is the dyno sheet on the XXL, kindly provided by Greg at High Voltage Kits. The kv of the XXL is 62 rpm/volt, the same as the XL and Big Block. The Small Block is the exception with a kv of 67 rpm/volt. I use the highest kv available from the factory. I tried the lower kv motors and noticed no increase in torque. They did make noticeably less rpm which meant either less speed or less reduction which actually equates to a reduction in torque. Torque windings may work for hub motors but my observation was that it wasn't desirable with these motors.
LightningRods said:I can’t imagine why you’d need more than nine gears. I haven’t sold dual chainrings in many years. I’d recommend a Wolf Tooth ‘Drop Stop’ front chainring in a 1x9. Your chain drop issues have nothing to do with the mid drive. It’s 100% the interaction between the front chainring and chain. Most commonly it’s caused by a worn chainring that has turned the teeth into hooks.
Some LBS mechanics can be amazingly ignorant and cowardly. When you find a good one you have a treasure
briangv99 said:10kW sure sounds like the figure to soon for.
I can't get to 8:1 gearing at the moment, best I can do is 7:1, preference is to use your 15t motor sprocket to avoid the worst of chordal effects of small sprockets.
I've had a couple 105t rocket kart sprockets on the shelf for the best part of a decade. That give me 7:1 at least until I can figure out how I can get a hold of a 120t sprocket.
Any ideas where to source a 120?
thepronghorn said:Are you using #219 chain? You could laser cut a 120 tooth sprocket from 3/16" aluminum. Not sure if you guys have something like https://sendcutsend.com/ in Australia. I lasered a #25 sprocket from 1/8" aluminum that's working quite well on my bike.
