spinningmagnets
100 TW
Temporary peaks of power can be higher, but 30A is a fairly safe limit for continuous loads, for motors this size.
edit: I am assembling a chart of various common motors' "tangential magnet speeds", so it can be discussed, and perhaps become a useful method to add to the others as a way of evaluating one motor against another.
A high magnet speed has the practial effect of lowering the amps drawn per a given load, compared to a low-RPM motor with the same load.
Worst case scenario: a small diameter direct drive hub (408?), large diameter wheel, long slow uphill, low volts / high amps.
Compared to: large diameter hub (Magic Pie?), small diameter wheel (20"?), flat ground, high volts / low amps.
Even better: BB_drive, shift down to a lower gear on steep hill, motor stays near 3,000-RPMs (GNG / LR / Ecospeed?)
