waynebergman
Hope I am not getting too off track here on the subject of the lag time in mid drives but I feel it is worth mentioning here.
For the version 3 CA on my Giant DH I have no feeling of lag what so ever with my mac 10t in the wheel.
EDIT: Actually there is some lag if no watts are going to the hub just before you hit the throttle, but if a small amount of current is going to the hub motor just before you hit the throttle it responds almost instantly and I think it is because of the mac clutch system. So if you feed the motor a tiny bit of current just before you need the power to come on you can get the feeling of no lag.
With the mac 10t in a different bike as a mid drive it is a different story because of the mechanical lag built into the mid drive system itself ( this is my opinion anyway ). I feel this is perceived because of all the free wheel stuff not being under load when hitting the throttle. If you are going up a hill for instance under load with a mid drive system and hit the throttle you don't feel the lag time like you do when coasting and then hitting the throttle.
Am I missing something here or are we talking about two different things? I see the lag time in mid drives as a bit of a bummer and not too much talked about when it comes to slow speed trials type riding. You are constantly fighting the jerky ness of it all during slow speed start up unless you are under load before hitting the throttle. I know on my poorly tuned gas dirt bikes the hesitation was overcome by revving up the motor and dumping the clutch which we can not do on our electric rigs.With my mid drive bike on the trails I have found myself going down hills with the brakes on and also the throttle on just enough to put some power to the wheel so the system is loaded, so then if I need to dump some controlled power into the system for short wheel stands climbing over obstacles etc I can do it with no feeling of lag. This is a bit of a pain but seems to be the only way to get rid of the lag time in MY mid drive system.
I have often wondered if a spare clutch in the mac hub motors could be used for the free wheel solution housing drive sprockets as there engagement is instant and also silent. Not sure what kind of power these clutches can handle but I feel a mid drive needs an instant engagement of any freewheels used in the drive train for a happy feel at the throttle. .........just my opinion.
