Nelsjourney
John Bozi; That is what I did. I disconnected the CA and used the original controller that I ordered from Lyen for his controller. I did what LR told me and disconnected the throttle from the CA and I also updated the firmware to V1.3. This worked and the throttle problem was fixed. But, Now the CA is registering 77V when I hit the throttle and goes back to 48v when I let go. I go to the initial settings in the CA and it shows 48v.
This is confusing. I disconnected the CA and am running straight from the throttle. I ordered a voltmeter/wattmeter from Lunacycle and when it arrives I will use this to gauge my battery. I don't need the fancy readings of the CA. The learning curve for the CA3 is too much for me right now.
I bought a Bafang BBSO2 and installed it on my hybrid bike and it is plug and play. So I have decided to use the Bafang for commuting and the LR for weekends to ride around the city. There are no trails here.
But thank you for your advise and expertise. I hope you find the drivetrain for your bike that will hold up to your style of riding.
Nelson.
Nelson.
