Lights
marty said:
Call or email
http://www.jwspeaker.com/contact_speaker.htm
Ask where to buy?
Or maybe Oviedo can get it. They carry JW Speaker.
http://www.oviedosafetylights.com/Shopping.idc?ProductCategory=21
I've been very happy with Oviedo's service!
-Cal
Deafscooter using HID lamp 35 watts , over 3,500 lumen at 5,000 Kelven Color Temp
Very Bright Blue/White Light than ALLLL Led , Halon 55Watts , Flood lamp , Bike light
Ready to use ( easier to install Hid Headlight to your Scooter or Bike
See here ---->>> http://www.rallylights.com/hella/Micro_Xenon.asp
Also My EVT-168 SE Red Scooter have HID HeadLamp to Brightest Light..
For Expert User to install your own Headlight or Modding your Light to HID Lamp
=======>> Warning The high Voltage at starter lamp is 25,000 Volts <<========
IF you plan install hid in your own head light on scooter or e bike then make sure
ballast module to HID Lamp inside place and there make sure grounded to metal!
Craig Uyeda
Deafscooter
Lumens per dollar, auto HID is tough to beat, and at 35W its not too bad as far as power draw either. You can pull some projector internals from a light housing at an auto salvage yard for cheap. Ditch the big housing and it'd be nice and compact. If I needed lots of light I'd look it to doing it that way.
SWEEEET! :mrgreen:
Yeah--except the link says "This lamp has been discontinued and is no longer available."
-Cal
It was way too expensive anyway. I checked that one out a while back. I think a few of the pro motoX guys used those helmet mounted in the baja 1000.
