Lishui LSW913-62-6F Controller: Wiring Check & Display Compatibility Issue
othmane
🧲 New user
Morocco
Hello everyone,
I need help with my e-bike setup. I am using a Lishui (LS) controller, model LSW913-62-6F (36V).
1. Wiring Check:
I have attached several photos of my current wiring. Could you please check if the connections between the battery, motor, and the main harness look correct? The system powers on, but I want to ensure everything is in its right place.
2. Display Problem:
I am currently using an M5 LCD display (Green Julet 5-pin connector). While it powers on, it doesn't show the speed or any motor data. I suspect a protocol mismatch since the M5 is likely UART2 and my controller is Lishui.
3. M5 25P Compatibility:
Does anyone know if the M5 25P version is compatible with Lishui? Or should I stop trying with the M5 series altogether?
4. Recommendations:
Which display models are confirmed to work with this specific Lishui controller? I've heard about KD21C or SW102 (Lishui versions), but I want to be 100% sure before buying another one.
Thank you for your expertise!
