DanGT86
I made this for my disk side sprocket adapter. It drives off of the star pattern because I don't like using the bolts as pins and was uneasy about the friction being enough to hold it. Its about a .003 slip fit over the hub star. Then I preloaded it against the "teeth" by twisting it CCW before tightening the bolts so it wouldn't wiggle under load. No regen or back load so it should stay loaded against the star keeping the bolts totally out of the torque equation. The real advantage was that the flange the bolts go through was super thin to get me maximum brake caliper clearance. If the flange were driving i would have needed to make it thicker to feel safe. This would be a hassle to machine for unique hubs but if you decide on a standard hub they should all be the close enough to standardize your adapter. Now If I could only find the time to finish the bike I could report on how it works.
