bzhwindtalker said:
We asked all manufactureers of torque sensor at eurobike and none had a 100mm torque sensor, let alone Isis type...
Depending on the way you will handle the pedaling chain ring, and if you have a pedaling chain independent from the motor chain, you may want to have a look at the BEAMts sensor.
It is a Torque sensor that measures the tension in the pedaling chain, and applies throttle proportional to the pressure on the pedals, which is the most natural and intuitive pedal assist you can get (super human feel).
It is a throttle pass through system, so very easy to implement, It self calibrates, but they also have a programming tool for it.
It does not work for mid drives with a common chain for pedaling and motor (sensor would respond to motor induced tension), but if you have a separate chain system for pedaling and for the motor, it could actually work on your mid drive configuration. Below are a few links about it.
The developers, SantamonicaEV:
http://www.santamonicaev.com/page12/movies/index.html
http://www.beamtssample.com/page-2/index.html
US Reseller
http://www.ebikes.ca/beamts.html
User feedback thread
https://endless-sphere.com/forums/viewtopic.php?f=3&t=67086
EDIT:You are probably right about 100mm BB, I only found a 128mm ISIS one
http://www.ebikes.ca/isis-128.html
The one below does mention Custom size, so they may be able to accommodate a 100mm request
http://www.sempu.net/goods/detail/35.htm
I also found this one in 114mm
http://www.ebikes.ca/shop/ebike-parts/torque-sensors/tdcm-114.html
And these with no specification of size:
http://www.ncte.com/standard-sensors/pedelec-sensors/
