dan974
Light Mx project 2 / breizh
Proud of is celtic origins
certainly
chromo and mild steel have the same Elastic modulus...like all kinds of steel. So stiffness is the same.Tench said:I disagree that cromo and mild steel are similar in their properties!crossbreak said:stiffneess of chromo and mild steel is the same for sure.
Tench said:I recently helped my son fit a bigger intercooler on his car, he hung this from the reinforcing beam behind the front bumper, at first glance this looked like any other sheet metal pressing but drilling it was a different matter, I have a set of quality cobalt drills that are sharpened professionally in a machine with diamond faced cutters, they look beautiful! but they would not touch this cromo steel, so I disagree that cromo and mild steel are similar in their properties!
GCinDC said:this is a thing of beauty. congrats!
what motorcycle was the seat subframe from?
why the pedals? why not footpegs?
got a link for this big block motor? is it stock or has it been rewound?
madin88 said:i very like the frame and the Big Block mid drive.
do you have plans to improve the chainline or do you leave it as it is?
imho a bigger front and rear sprocket would lower the chain noise and improve a bit efficiency (less rubbing against the plastic part above the swingarm bearing).
with a very big rear sprocket (1:10 reduction) and higher voltage the power would be crazy, but forced motor air cooling would be necessary i guess..
you did a good job. thumbs up for this build!
skeetab5780 said:with a SS 1:10 reduction wouldn't he need to run about 40S (168vdc) lithium to get only 35mph...or am I thinking of something different
~also curious if larger sprockets will cause chainline/swingarm interference
bzhwindtalker said:New video, Still on 12S, (shipping issues with new battery)
Enjoy
