isaac_alaska
- Joined
- Sep 29, 2011
- Messages
- 70
i'm trying to discharge my li-po packs a little quicker than the 1.5 hours that it currently takes with my hyperion charger (it only discharges at 50 watts)
i'd like to find about a 1ohm resistor that can handle 500 ish watts. know of any sources? (old tv's, etc.? i can't think of anything right off)
i'd also like to be able to turn the load off automatically when the voltage reaches a desired cut off voltage. i built a small add-on circuit to the bm6 that gives an active high signal of about 4.7 volts when the voltage reaches the cutoff programmed into the bm6 chip. what's the best way to set this up so it will remove the load when it receives an active high signal? i think the current output is only a few mA from the chip, maybe 12 mA
