mcintyretj
Hi electrical experts. I have a harbor freight tools 100w solar unit. This system consists of 4 x 12v panels hooked up in parallel. It also comes with a 12v charge controller, which I used until my lead acid could no longer hold a charge over night. Lately, I have been charging my 30ah battery (15s) with the panels in series. It gets my battery about 1/2 charged so I usually charge for a few hours at the end of the day after having it on the charger for 90 minutes in my classroom.
Here in my battery charging, the no load voltage, and at the end of the day:
My plan is to purchase another HFT 100w solar charging unit ($149.00 on sale) and charge my bike with 100% solar power by running 2x 4s solar panels. If I had a good BMS it would not be a problem, however, The cheap BMS units I tested, do not seem to balance or have a HV cutoff. So, I have been looking for a simple high voltage cut-off circuit that I could set somewhere around 62 volts. I have looked at modifying a 12v circuit. Here is the schematic and board:
Here is another HVC system that might work:
I was hoping a 62v shut off would be just be a few resistors, diodes, and a transistor (FET). Can anyone point me in the right direction?
Thanks
Seal Beach, CA
Thanks
Seal Beach, CA
