Eujangles
Hello ES,
Thanks in advance for any advice you guys can give!
I recently sold an ebike from the stable, which has allowed me to take on a new build![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here's the plan so far:
-Light weight single-speed bike
-Q100H 201 RPM, rear wheel
-KU93 Controller
-48v 10ah
Here's my problems:
-I'd like to use an aluminum frame to drop some weight. I know that it is not recommended to do so, but I also know that there are people here who have done it successfully. Yes, I will use torque arms. What do you guys think? Is it such a big deal on rear dropouts, that are already meant to take some torque? Also keep in mind that I'm not dumping tons of volts into it, so hopefully the strain on the dropouts won't be so bad? I'm all ears if you guys think this is a bad idea...there are lots of great steel-frame single speeds out there.
-I'm a bit worried about the spacing on the 120mm dropouts with an aluminum frame, seeing as I can't exactly bend the aluminum if I need more space. Another ES member here (chas58) managed to fit the Q100 in some 120mm dropouts, and actually fell short, and had to use a washer to fill in the space: http://endless-sphere.com/forums/viewtopic.php?f=3&t=49691&p=738009&hilit=120mm+q100#p738009. So with that in mind, do you guys think it's a big risk for me to buy an aluminum bike, or does it look ok to you, since the q100 doesn't actually fill up the 120mm?
-I know some people here have had problems using the KU93 on the Q100, however, I think those people were likely trying to use it on the 328 rpm model. On the gf's bike, I have been running the original Q100 201 rpm, on the KU93 for about 3 years with no problems, which is why I am ok with doing it on my new build. However, do you guys think I should be worried that the 30% extra torque claimed by the Q100H will be too much power at 22A for those little gears? I'm open to just using another original Q100, but I like the black casing and am tempted by the higher torque of the Q100H, which is why I am hoping I can use it instead.
-I'm 100% open to suggestions for different controllers, or going up to the 260 RPM version of the Q100H, but I'm pretty certain I can't run that high RPM safely with the KU93 controller. I've looked into what some other people have done to accommodate 48v on the Q100H 260rpm, and it seems most of them have modified the living hell out of a KU63. I do not have the expertise to do this, so would just be looking for a stock controller that can handle the Q100H and 48v. I'm not too hung-up on pumping out amps (14-18 would probably be more than enough for me at 260 RPM), I just want a zippy bike with a top end of somewhere around 40km/h (I won't be upset if it's a little lower than this).
-Do you guys think I am better off going with the 260RPM model and getting a CA to limit the amps for the KU93 with?
Thanks again everyone!
P.S. If anyone out there sells modified KU63's that can handle 48v, please let me know! I'd love to have one of those at a lower amperage (14a-18a) so I could move up to the 260RPM model![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
-KU93 Controller
-48v 10ah
Here's my problems:
