I have a video of a real world test at 130 amps but I just knoticed I don't have a video of the 200 amp test.zombiess said:Arlo1 said:As well I've put over 200amps through a TO247 leg for over 10 seconds. The continus rating of 120-160 amps DC with proper cooling is nmo lie!
Stop, put down the Koolaid they have you drinking. You will not be putting 120A continuous (not 10 seconds) through the legs of a TO-247 package continuously without a very extreme cooling method..
THIS IS REAL WORLD! I did these tests to find what worked good for heat and electrical conduction from the back of the fets.
200 amps though the legs is doable for over 10 seconds this is no bull shit.
Luke can back me up on this.
The data sheet is not Koolaid if and ONLY if you stay with in all the parameters of the power switch. The tricky part is to stay with in all of them at once!
The desat circuit and temp monitoring as wall as great cooling at all steps to doing so!
