liveforphysics
100 TW
flathill said:liveforphysics said:It lives.
It rips.
Motor still gets overheated in about 5mins.... kinda pissed about that, but after hours of professional Sevcon dyno tuning, it runs and doesn't fault out. The controller gets warm, the battery stays cool, the motor gets flesh-burning hot.
Maybe the gearing needs optimization. What rpm were you making peak power? Peak power and peak efficiency are almost never coincident. Maybe you need to be in another band.
Glad to read you guys finally got the sevcon dialed.
Yeah, I also think that's part of the problem. I wanted to try to calculate the longest straight at the grange track, estimate the speed I would enter it, and gear the bike so I wouldn't be running out of gear, but it looks like I'm going to need to re-gear it a bit to help the motor survive. Im running a 24t front and 71t rear right now with a 24.1" diameter tire, and a 6,500rpm motor RPM limit. I'm going to try throwing a 20t or 19t on the front and see if the motor temps drop.
