Magic Pie 4 (Vector) conversion build
voltaj
100 µW
I hope this would help others build their Magic Pie e-bikes and also help me get some answers
Before photo:
A ~5 year old Schwinn bike from Costco with 26" wheels.
All the parts I got from goldenmotor.ca
48V10AH LiFePO4 Aluminum Cased Battery
Seatpost Battery Rack
Rear Torque Arm
USB Programming Cable for Magic Pie 4 VECTOR and Smart Pie 4 VECTOR Controllers
Magic Pie 4 (VECTOR) 24 Inch Rear Conversion Kit (Throttle: 48 Volt Twist)
Challenges:
1) The parts come with ZERO instructions! :x Assembling the seatpost battery rack is gonna take some guessing since I cant even find a clear photo of it assembled online.Seatpost battery rack IMG_3788_resize_resize.JPG
2) I cannot replace my brake levers because they're one piece with the shifters:IMG_3792_resize.JPG
So I might get the hidden wire brake sensors http://www.greenbikekit.com/hidden-wire-brake-sensor.html
I wonder if they're reliable to cut off the power and compatible with magic pie.
3) I want a half twist throttle, not available from golden motor so I'll have to shorten this one:IMG_3789_resize.JPG
What is the widest tire that would fit on this rim?IMG_3802_resize.JPGIMG_3803_resize.JPG
The Golden Motor battery rack RAK-002 assembled:golden motor battery rack assembled_resize.JPG
The seatpost was not straight (the holes for the battery plate wouldn't fit) and required some bending. Some of the screws are a little too long.
The support struts for the battery rack are supposed to be fitted to the seat clamp bolt.
Original disk break screws were too long, hitting the controller. Using washers is not an option because the screw heads will hit the motor cable. I had to shorten them about 3mm.View attachment 1102 flywheel tool.JPGvery important to use this washer otherwise the flywheel will lock up on the wheelView attachment 9for an 8 speed flywheel you need 3 spacer washersView attachment 805 half throttle cut.JPGIt's much more comfortable holding a half throttle for longer periods of time06 half throttle.JPG A temporary solution for using regen ebrakeView attachment 5extra cable hidden in a pouch08 hidden extra cable length pouch.JPGrear torque arm V408 torque arm.JPGView attachment 2This is how I decided to mount the battery support, because I didn't want to have it on the seatpost (too high, and it's annoying to adjust the seat height). I had to bend it a little bit more to make sure the wheel doesn't rub on it.
For the ebrake levers I decided to use reed switches normally closed. The smallest I could find are the MK24 (type B are normally closed):
http://www.meder.com/fileadmin/meder/pdf/en/For_Showroom/PS201008_MK24_Series.pdf
order here: ($7/piece)
http://www.digikey.com/product-detail/en/MK24-B-2-OE/374-1136-1-ND/2421995
The Mk-24 B reed switches are really smallmk 24 reed normally closed.JPGmk 24 reed NC.JPGmk 24 reed switch.JPG
I used buckyballs magnets. They only work in a certain position, find the right magnetic pole and the best position.glue the reed switch w epoxy here.JPGmagnet position.JPGdetail reed switch.JPG
Test:
https://vid.me/zBZn
