magicpie55
- Joined
- Dec 14, 2019
- Messages
- 3
Hello .... This is my 3rd magic pie setup I have always had pretty good luck with them but this one has me stumped .. The motor fits between the forks perfectly not to tight and no room needing shimming ... Trouble is the whole thing is off center 1+3/4 from fork to motor on one side and 3/4 on the other side ..the wide side is the one with the controller .. I wouldn't care but it makes the front brake pads crazy and binding ..straight pull brakes new electra townie bike .. the dealer has not been able to figure it out ... I have fooled with the brake shimming the dragging pad away from the wheel but I am not sure why the motor is off center ... I also have a smart pie 500 watt that I used for a couple of years ant it too is off center .. I only use the rear brake on that one but the front also has the regen braking .... Any help would be deeply appreciated ...
