safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Magnetized Wheel (A Theory Thread)
This is a "Theory Thread" so if you are looking for an "answer" to some practical short term question you need to go to another thread.
The idea here is to create a bicycle rim that is lightweight... close to the weight of a standard rim... and yet is given a magnetized condition so that a coil placed near the rim could recapture the cyclical energy during regen. In fact... one might even consider using the magnetized wheel as a brake in place of the standard braking systems.
These days there are some rather exotic materials being created that might be able to produce the magnetic properties desired. If just the right material could be discovered that could provide the necessary material strength for a rim while also giving it magnetism then you have the basis for all of this.
The idea is to make a sort of "super pancake" hub motor where the hub is stretched all the way out to the rim. It's NOT going to be a standard motor... and the idea might not even work very well... but that's why we have a "Theory Thread" so that we might do the thought experiment to consider what could be...
