teklektik said:
There are a couple of things that could be wrong: the trimpots may not be wired correctly
If this was the case, then I would imagine it would not work at all...?
teklektik said:
the Magura may not be a 5K unit but one of the wonky 4K/10K models,
Is there any way to verify this? The seller assures me its a 5K unit.
teklektik said:
or the controller may not like the Magura and may be loading it down.
Is this a common problem? According to the guy I bought the Bafang off, any 3 wire throttle should work...so it should work with the magura you'd think
teklektik said:
Some external measurements at the connector level are an easy place to start...
I'm assuming you mean where I connect the magura wire to the bike's harness wire. I did this by putting a probe wire in the connector for the brown and black wire, and plugging the harness in.
This is all AFTER the trip-pots.
teklektik said:
Anyhow, using the DC Volts setting, look at the voltage from from Gnd (black -) lead to the throttle 'sense' lead (brown +). We want to see the voltages at ZERO, 1/4, 1/2, 3/4, and FULL throttle.
Sounds silly, but I don't know what the DC volt setting is on my meter? Can you tell me what one it is?
The results I got from this by using the "20k" setting on the meter was...
0: 1.65
1/4: 2.20
1/2: 2.62
3/4: 2.88
FULL: 2.66 (oddly less than 3/4 throttle)
teklektik said:
Next let's look at the actual resistance of the throttle in these same five settings. Here you unplug the throttle and probe the throttle connector pins so the measurements include the trimpots - this shows the situation unloaded by the controller. Using the 'ohms' or 'K' setting, measure across the same two connections (Black+Brown) as above.
Ok. I used the "20k" setting on the meter for these tests.
Readings were...(I assume this was Black and Brown)
0: 2.02
1/4: 2.83
1/2: 4.03
3/4: 5.47
Full: 7.2
Does this look right? I also tried another combo (not sure what wires as I was plugging in at the harness) and got... I assume brown and blue.
0: 6.88
1/4: 6.50
1/2: 5.22
3/4: 3.7
Full: 1.68
teklektik said:
Last, measure the resistance (ohms or 'K' scale) across the throttle +5v (Blue) and Gnd (blk) connections while rotating the throttle - the reading should stay the same.
I'm getting these reading for what should be blue and ground.
0: 8.9
1/4: 8.82
1/2: 8.83
3/4: 8.86
Full: 8.90
I used painters tape on the throttle and marked 0, 1/4, 1/2, 3/4 and Full so I would get consistent readings each time.
