Main contactor?
HrKlev
Hi, all!
Im about to start an ATV conversion (QS138 motor, Votol 72150SP controller, 20 LEV40 cells, "bluetooth bms" from aliexpress are in the garage, ready for install) and I think I have got the most figured out. I've been lurking around this forum and learnt a ton the last few weeks, but I still dont quite get the main contactor. Why do I need it? Or do I? The votol has a input that turns it on and off, and I was thinking I can wire it to a key switch. In addition, the BMS can also be switched off, so I was thinking about wiring it up to a another "hidden" switch in case the ATV will be parked for longer periods of time. Do I need a main contactor in addition to this? Thankful for any insight!
contactors are used as a high-current-capable connection device (also high-voltage) to prevent damage from arcing during connecting battery to controller (because capacitors in controller take a large current momentarily as they charge up during power-on at connection).
they are also used to remotely disconnect the batteyr in case of system failure / emergency shutoff, and to completely disconnect a battery from controller/etc to prevent low-power-drain over time from killing the battery.
if your bms has a power switch then this should eliminate the above needs, except in one case, which while not common, does occur.
if there is a failure of the system in a way that causes the bms output fets to fail in their most common failure mode (shorted on, but at higher than normal resistance), the bms power switch no longer works, and there is then no way beyond physical disconnect of the battery from system to cut power.
often enough something tht damages the fets in this way is dramatic enough to require such disconnection to stop the drama part. ;)
so, instead of a main contactor, you could instead use a battery cutoff switch that's rated for teh voltage and current you'll be using, along with whatever main fuse you're also using to protect against shorts causing a fire.
the switch can be an actual switch, or it can be something like the anderson sb-series (or any other large sturdy connector that requires sufficient force to unplug that it can't be done by accident) that's got one block bolted to the atv, and one that's plugged into that block with a t-handle to pull in case of emergency disconnect needs. the plugin block is simply wired as a jumper across both terminals. the bolt-on block is wired to batery positive output on one side, and to controller battery positive input on the other.
or you can go without, and just physically unplug the battery as a final line of defense.
Thank you for a well written answer! I think I will stick to the plan then, and turn the ATV on and off with the controller for daily use, and wire up a switch for the BMS for emergency or storage for longer periods. I will also have a Anderson 175 between the battery and main fuse for a last line of defence as you say. It is a good tip to rig them up with handlebar and bolt the other end to the ATV, in case I will be in a hurry, I didnt think of that. I'll see what I can rig up!
pull handle
https://www.google.com/search?newwindow=1&biw=1076&bih=594&tbm=isch&sa=1&ei=-JcqXteWF7LP0PEP2-Ia&q=Anderson+sb175+pull+handle&oq=Anderson+sb175+pull+handle&gs_l=img
panel mount
https://www.google.com/search?newwindow=1&biw=1076&bih=594&tbm=isch&sa=1&ei=-5gqXuHpLpS-0PEPtsKR-A8&q=Anderson+sb175+panel+mount&oq=Anderson+sb175+panel+mount&gs_l=img
amberwolf said:
contactors are used as a...
That was an amazing response amberwolf, Thank you kindly.
I too am looking at the "emergency pull switch" vs "electrical contactor" design.
A con that comes to mind around the manual method, is the delay in seconds from smoke pouring out of a BMS inside my case, to me pulling the kill switch. A contactor could be setup to disconnect quickly on a variables; bms temp, case temp, pressure switch (battery case is expanding due to venting lipo) fallen off bike seat, etc.
Thanks again
If you've got a BMS "on fire", you'll likely need more than a contactor or pull-disconnect to stop that part. ;)
The contactor and the pull-disconnect are usually meant for differnet purposes. So which purpose you have for it determines which one you want to use.
A manual-pull is usually for either safety (on a lanyard tied to you so if you fall off in a race/etc it disocnnects power to stop all motor action so you don't get eaten. ;) ), or security (take it with you, if it's not a common connector you'd get some measure of antitheft that way), etc. Can also be used in an emergency to purposefully disconnect, but as you say, there's quite a delay in reaction time, etc.
If you need *any* automation of disconnect, a manual-pull isn't suitable, unless you are building some form of automated mechanical "ejection" system for the manual-pull (not impossible...but I'd just use a contactor in series with a manual pull, if you really need both).
