It is due partly to that, and also to the low resistance of whatever connection you have between the cells.
But there is always *some* resistance between cells in parallel, and so they are not always exactly the same voltage. As long as the cells that are supplying the most current are not sagging in voltage, then those plus the other cells in parallel will be at the same voltage.
As soon as the cells supplying most of the current begin to sag (internally), current will begin to flow thru the parallel connections from the other cells that aren't sagging, and there will be a minute voltage drop across the cell interconnects during that time--for that time, the paralleled cells will indeed be at different voltages.
Really, that's irrelevant, but just thought I'd point that out for those that dont' see how they can be at different voltages in parallel.
